Question about LG Washing Machines
The washing machine turns it self off after about 10 seconds.
  • Colinjudyt Nov 04, 2008
    no id doesn't get that far before it turns off.
  • Is the water coming in?
    Sergeant:
    Champion:
  • 324 Answers
Sounds like its your control board.try unplugging it then plug it back in.
Posted on Nov 04, 2008
How do i reset code F21 to a Bosch Maxx 7 washing maschine?
Turn knob to 12 o'clock position
turn to 6 o'clock position
press an hold the spin button
turn knob to 7 o'clock while still pressing the spin button
let go of the spin button after 5 seconds
turn the knob back to 12 o'clock
assuming you have repaired you're f21 motor issue it should behave its self
Mar 27, 2015 | Bosch Washing Machines
My washing machine keeps blowing the fuse when I turn it on after about 10 seconds , any ideas
If washing machine aging, that possible damage heating element. Necessary so- check Drain and hit of water on electronics.
Mar 07, 2014 | Indesit W 123 Front Load Washer
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
Dec 07, 2013 | Kenmore Washing Machines
All lights flash display reads "power out self reset in 10 seconds".
Display reads power cut restart in 10 seconds
The motor controller board has a switch mode power supply problem.
Best to get a new motor controller board Or a technician to look at it.
Look at the 6 digit part number under the bar code to get the right part for your machine.
Nov 22, 2013 | Fisher Paykel Eco IWL16
Washing machine was operating machine stoped 10 minutes after operating and will not start water is in the machine it did not drain
Hello, first check if the breaker triped in the electrical panel box (fuse box--old name). If it has not triped a breaker. Unplug your washing machine and wait about 10 or 15 second and replug the washing machine into the electrical socket. Don't turn it on. There should be a reset button. Push the button first, then turn on your washing machine. I hope this works for you. GB...stewbison.
Aug 25, 2011 | LG WM-2277HW Front Load Washer
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Sep 05, 2008 | Indesit W 123 Front Load Washer
Kenmore 100.27731600 Washing machine Blows circuit breaker
let me know could be the breaker its self with the timer off should be no power going to the washer
Feb 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machine GE Profile/prodigy
you have a dry on your programmer you should not do this your self i would go down and see your local second hand shop who can help you with is they normally do jobs like that appliance shop is the best place to go it will be cheap
Dec 03, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
