Question about Panasonic PT-47X54 47" Rear Projection HDTV-Ready Television
TV Screen pauses, looks like a puzzle, then starts again..................???
I have a 3 year old Panasonic PT 47 x 54. Have had burn in twice, had bulbs changed twice. Burn in is back, but, not the problem. About 4 times an hour, the screen freezes, then looks like a jigsaw puzzle, then, starts again where it left off. Lasts about 3 seconds, but, the more it happens the more annoying it is, any ideas??? It happens also, when I am watching a DVD. Thanks in advance.
  • ainie Jan 18, 2008
    the Toshiba tv screen looks like a jigsaw puzzle -- It just happens from time to time -- After the tv is on a while, it is impossible to watch -- the sound as well as the picture is so severely compromised. As nearly as I can determine, it is not on all channels. I have a small Panasonic tv in the kitchen but that tv does not seem to have that problem.
    I called Comcast and nothing seems to be wrong at their end.
    President:
  • 3,130 Answers
Your problem is in the digital video processor circuit. This is a hard puppy to trouble shoot unless it happens all the time. Most of the sets I have seen do this, the main video processor IC is drfective and the repair was around 3 to 4 hundred bucks.
Posted on Sep 23, 2006
I have a Panasonic Model Number PT-56LCZ70, it is only a little over 3 years old. I have had to replace the lamp unit twice, now the TV just goes off and the red light blinks 8 times. We have done what...
There is a sensor where the door of the bulb is located. You will need to purchase (or by-pass) the door sensor to allow your tv to function again. It is located inside the small hole nearest the screws for the bulb door.
Thank you and please rate!
Apr 11, 2011 | Panasonic Televison & Video
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT61LCZ70K panasonic tv won't turn on, flashes green light for a couple of minutes then flashes red twice then stops and flashes red twice again. TV Made in Feb 08 lamp shouldn't be gone yet. Manual says...
have a tech clean inside cabinet and replace bulb , should be under warrantee if under 5 years old just had mine done free of charge from panasonic call 1 888 843 9788 they will direct you to a dealer. hope this helps
Oct 01, 2010 | Panasonic PT-61LCZ70 Television
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic multimedia projection HDGT tv color spots displayed
PANASONIC..PT-52LCX15. STARTED TO A LIGHT COMES ON THE SCREEN. THEN TWO LIGHTS. FINALLY TV DONT COMES ON. I PUT ON THE TV, AND ON BOTTON START BLINKING AND TV DONT COME ON..I TAKE OUT THE TV LAMP..IT LOOKS GOOD NOT BURN. SHOULD I REPLACE IT??
Oct 18, 2009 | Panasonic Televison & Video
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Has a orange and green spot on screen tv is 3 years old
Call Panasonic and request for correction tool(software update) part#LSUQ0100. This comes with the instruction. Try this first before suspecting light engine.
May 21, 2009 | Panasonic PT-52LCX65 44" HDTV
3 green dots on my screen
sounds like crt burn in.. how big..do the come and go.
Dec 19, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-51HX42F
Sometimes, in the Panasonic projection sets, one of the convergence IC's shorts out and draws so much current that one of the resistors next to it glows red hot. The computer senses the extra current and shuts the set back off. This is quite an easy problem to correct, but the set should be serviced by a qualified tech familiar with panasonic projection sets.
Aug 23, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-47X54 47" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
