Question about Microsoft Windows XP Home Edition
Re-install OS/windows xp home
I have a P3 desktop and i want to reinstall windows XP home editions, after all the drivers are loaded. It gets to a point where it ask me to select the partition, when i select the partition it says this: Setup cannot access 6150MB disk 0at id on bus o on atapi (MBR). I try to delect the partition but it won't work, i try to creat a new partition it won;t work, i even trry to repair the windows XP and it won't work. Can somebody help with PC on what do to, to bring it back to life.
Thanks
  • 17 more comments
  • sefamaxwell Nov 02, 2008
    Thank you, but the problem is the present partition will not delete. The computer brings out an error message that the partition cannot be accessed. What should i do.
    Yes my laptop
    OK, i will try this, the problem is i don't have a floppy drive on my Laptop, but i will try the other option and get back with you soon.
  • sefamaxwell Nov 03, 2008
    I did everything, now when its getting ready to load this message comes up:
    STOP :0X000000050(0XE5151E48,OX0000000, OXFB79DC13,0X00000002
    SETUPDD.SYS-ADDRESS: FB79DC13 BASE AT fb771000, datestamp 411107c8f.
    What does it mean and what should i do
    It also says the computer has encountered an error and has been shut down prevent damage to the rest of the computer
    OK, Thanks so much, i will try the floppy disk thing and let you know. I have to go to a friend to get it done. You have been very helpful. I appreciate it
    Ok. I finally got the floppy drive and made the boot disk, when it finished as you stated, and when i typed fdisk, it says its a bad command. Any suggestion
  • sefamaxwell Nov 04, 2008
    I just found this out. I typed in Ver to see the version, it came out as Windows ME. Does it mean two OS were operating on the same machine. What should i do?
    I am sorry to be bothering you, but i downloaded the 98 bootdisk, but when i put it in, it says invalid system disk.
    That i am not sure about it. But i think it is NTFS.
    The error from the 98 bootdisk is Non system disk or disk error
    Thank you soo much. I really appreciate all your help. YOu have been very helpful. Thanks alot.
    Sure will. Thanks again
  • sefamaxwell Nov 07, 2008
    Mumma_1, i just want to let you know that finally i have my PC running again. I finally got to format it using the XP CD, after following the steps from Steve's website. I just want to let you know that i appreciate your help immersely.
    Thanks so much
    I couldn't have done it without your help. It will be an injustice, for not letting you know. Yes, this relief is bigger than you can imagine. One thing though, do you have serial numbers of XP PRO.
    Thanks again
  • sefamaxwell Nov 10, 2008
    Hey its me again, i have a friend's laptop, and trying to reinstall XP on it, but after the first load of the files, it said checksum is bad, or corrupted. What is a checksum and how do i fix it to continue the instatllation. The PC is Inspiron 8600
  • Anonymous Dec 27, 2008
    i need a genuine copy of windows xp cd and a new product key free where can i get it?
  • Anonymous Jan 03, 2009
    windows xp professional set up has been installed and running when it stops and say "windows cannot load set up" error code 7, I try installation it again and it says "error coade 4, is there something bad in my motherboard?
  • jovern_2k7 Jan 07, 2009
    i can't access to the control panel
  • Debs
    Debs May 11, 2010
    When you say it asks you to select partition, how many partitions do you have? and do you get the option to delete a partition?
Error 0X00000005 on hp officejet all-in-one and it will not print now
Posted on Feb 13, 2009
  • 903 Answers
Checksum is bad, normally indicates an error in the cmos. It could be the cmos battery needs to be changed (looks a bit like a watch battery on the motherboard), it could be caused by an updated bios, or a virus. Or when a computer is not shut down correctly it can corrupt the cmos.
If the bios is not recognising the cmos settings then change the bios settings to default, and this could remedy the problem.
Then the battery (on the motherboard), and replace it with one of the same.
Posted on Nov 11, 2008
  • 903 Answers
Delete the existing partition, then use the maximum space available for creating a new partition. Once the partition is created, windows will perform a quick format of the drive. If at any time you are asked to use maximum space always say yes. Once the format has taken place it will ask you where you want to load windows, choose the partition that you just created.
If you need any more assistance please post a comment not a solution and I will get your message.
Hope this helps you
Posted on Nov 02, 2008
  • 11 more comments
  • Debs
    Debs Nov 02, 2008
    Do you have access to another computer with XP already installed?
  • Debs
    Debs Nov 02, 2008
    If you have a floppy drive on your laptop, insert a disk into it and go to my computer. Right click on the floppy drive and click on format. Once the format dialog box comes up click on create boot disk. To creat a boot disk. You will need this to insert into your PC to Fdisk it and Format the drive. Do you have a floppy drive on both computers?
  • Debs
    Debs Nov 02, 2008
    If your harddrive is problem free you should not have a problem re-loading windows. Do not run windows then insert the disk. Go to your bios options by either pressing F1, F2 or delete when booting up, depending on which pc you have and choose CDrom as your priority boot option.
    Insert the windows disk and reboot, when windows loads you should get the option to wither upgrade or install a fresh installation. Choose fresh installation, then you should have screen that will ask you which partition you want windows to load. If you click on the active partition you will have the option to delete the partition by pressing 'D' you will be asked to confirm that this is what you want to do, say yes. The screen will come back again with where you want it to be loaded and the 'C' drive should be displayed along with how much space you have on there. Choose this, and when asked if you want to use maximum space say yes. Then windows should start to install with no problems.
    If you try to delete a partition while windows is already running it will not allow you to this. Make sure you always boot from the disk, not switch the pc on then try and boot from the disk.
    Hope this help you if not try to create a boot disk as i explained above. And then get back to me.
  • Debs
    Debs Nov 02, 2008
    Okay I hope this works for you
  • Debs
    Debs Nov 03, 2008
    you need to format the drive. It sounds like the problems are all OS related. If you have a floppy on your Pc then you can load a boot disk. If you cannot create one on your laptop then ask a friend who has XP to create a MS-Dos Startup disk, by inserting a blank floppy disk into their drive, go to 'My Computer' right click the floppy click on format then click on create MSDOS Startup Disk. Once this is done. Then load the disk into your pc and reboot. (in the bios set the boot options to 1> floppy 2>cdrom 3>hdd or ide 0. When the disk has loaded it will finish with an A: on the screen. Type Fdisk and the partitions will be displayed. Delete all the partitions then create a partition and use the maximum space. Once the partition has been created to will need to format the drive. Press esc. to get back to the dos screen and type reboot, to boot your machine again. When the dos screen comes back on type in format C: it will tell you that everything on this drive will be deleted are you sure press or type in Y. Then press enter. If it asks you if you want large disk support at anytime say yes or enter Y and press enter. Once C drive has been formatted it will say something about a label or press enter for none just press enter. Once it has been formated it may ask you to reboot again. If it does just reboot. Put your windows disk in (this must be a full version of windows not an upgrade otherwise it will not work) and type in setup. This should kick your cdrom into play and start to load windows.
    Your current windows registry is very unstable and will cause problems. This is why you will need to do a clean format yourself.
  • Debs
    Debs Nov 04, 2008
    ok, sefamaxwe532...the problem is which I should have forseen and I apologise for not doing so, is that the XP boot disk does not have fdisk.exe on it. (sorry), if you go to www.bootdisk.com and download bootable files for windows 98se straight onto a floppy disk this will have the required fdisk.exe that you need. Then follow the instructions above. Once you have typed in fdisk you will get these options
    1) create dos partition or logical dos drive
    2) set active partition
    3) delete partition of logical drive
    4) display partition information
    initially type in 4 to find out how many partitons you have, then press esc to go back to the option screenm then type in 3 and delete the partition press esc again then press 1 to create the partition as said before if asked for large disk support say yes, if asked to use maximum space say yes. then follow the instructions above. I am really sorry for making you run around for this boot disk and I should have realised. I have formatted enough computers to know better and I apologise, but we will get there in the end.
  • Debs
    Debs Nov 04, 2008
    If you had two OS running on the same machine, it would have gave you the option to boot using either one (when it was running). Meaning that your drive would definatley have more than one partition.
  • Debs
    Debs Nov 04, 2008
    i am logging off now but will check back in tomorrow
  • Debs
    Debs Nov 04, 2008
    do you know whether your system was NTFS or FAT32?
  • Debs
    Debs Nov 04, 2008
    http://www.michaelstevenstech.com/format...
    I want you to go here, and look at all the available options you have open to you to be able to get your system working again. It is a valuable site to look at and will have lots and lots of solutions for you.
    I have taken you through all the solutions that I know, and if the disk is coming up as an invalid boot disk then I can only presume that all of the necessary files are not there. I have never had this problem loading, formatting or fdisking any computer, and have done loads over the years. Try looking through the site and if necessary download another boot disk instead, you will be able to it from inside the site that will link you to the necessary boot files. I feel really useless because I have not got your computer in front of me. I hope this site can help you out.
  • Debs
    Debs Nov 04, 2008
    you are very welcome and all the best....let me know when you have it up and running again.
    Take care
  • Debs
    Debs Nov 07, 2008
    I am really pleased that you have it up and running again, I bet that is a big relief for you, I know how much of a headache it can be when computers crash. Thanks for letting me know, and thanks for rating.
    Take care
  • Debs
    Debs Nov 07, 2008
    Sorry I don't, I run Vista now and have passed my old PC's on.
It only brings out one partition, and yes it gives me the option to either delete the partition or install on the partition or create another one.
Sllow prosess when i installed window xp in p3 system
These processors can support upto Windows 98SE.
Try with Windows XP Home Edition and have sufficient RAM min 512MB, Then it will be good.
Regards
Nandu
Sep 27, 2012 | Intel computers9: P3 933 Slim Desktop...
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
Xp reinstallation cd only installs operating
you need to update it by internet, or purchasing it online
Feb 18, 2010 | Dell Computers & Internet
Windows XP background loads but no icons/task manager/start menu
well copying the files may be the problem! for instance you need a recovery cd or dvd if you made one and use that to reinstall ur OS like the day you bought it!
try making or getting a windows installer disc then either install ur original OS like home or professinal or use the repair feature that shoud install all the drivers and .dll file you need
Aug 27, 2009 | Microsoft Windows XP Home Edition
Wont boot into safe mode, hold up at loading driver acpi multiprocessor PC
do you have XP bootable CD? If yes goto BIOS settings and select primary booting device CD Drive and save settings and exit. After restarting your system You will be asked to press any key for installing the OS.
Oct 29, 2008 | Microsoft Windows XP Home Edition
Windows xp home edition reinstall
If you use his disk, that will be better, because if it is original HP disk, it should install all original drivers at all, however this may delete all files on the computer depending on the type of installation you do.
Installing an older version of XP home does not make a big difference , as windows will update the system using automatic updates. What must be done, is ensuring that all proper drivers are installed.
Check device manager, in control panel/system, and see if all devices are installed with proper drivers.
Oct 26, 2008 | Computers & Internet
Reinstalling Windows XP Home Edition on Gateway 500XL
Do you have access to another internet connected computer that you can use to create a "slipstream" installation disc for XP. It will make your life a whole lot easier, and save hours if not days of downloading updates. Please read this article, and if possible, follow its instructions. http://www.theeldergeek.com/slipstreamed_xpsp3_cd_final.htm
Also, be aware that you can download all the original drivers from the Gateway web site if you use the serial # to look them up. The serial number is usually on a sticker on the side of the front of the tower near the CD drive. If you don't have the original CD with Drivers written on it, you may have to download these in order to get back online, etc once you load the OS.
Sep 13, 2008 | Gateway 500XL PC Desktop
Pinnacle TV card will not work in 761mx (gx-968) motherbd. Pinnacle Ref: 203560713235309122. Windows sees and loads one driver, but original driver does'nt load.
http://www.twenga.co.uk/specs-PCTV-Hybrid-Pro-PCI-310i-PINNACLE-TV-tuner-card-114949
see the link
Software / System Requirements Software Included Pinnacle Studio QuickStart, Pinnacle MediaManager 1.1 OS Required Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Media Center Edition 2005 Peripheral / Interface Devices CD-ROM, DVD-ROM, DirectX 9.0 compatible sound card, DirectX 8.0 compatible graphics card System Requirements Details Pentium 4 - 1.8 GHz - RAM 256 MB - HD 5 GB
Jul 21, 2008 | Computers & Internet
Restarts after XP loading screen due to SP2
1, the problem can be resolved repair, reinstalling windows.
Boot from the windows Os cd , Press Enter on the first prompt, Accept the liscense agreemt by pressing F8 and press R on the third screen to repair windows.
You also told that the hdds that you are istalling are 300GB each,in some cases you need to install the hdd drivers to get them to recoganise them correctly . The same is given by the manufacturer on a CD.
Apr 06, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
194 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
