Dynex Wireless G Router
My computer is connecting to the Dynex Wireless G Router but it's not providing me access to the internet.
  • JDTec
    JDTec May 11, 2010
    What ISP (Comcast, DSL etc) do you have. Need to know to give you right direction to go in.
I would like to add a computer to my existing wireless router, but i dont have my password. How can I retrieve it?
Posted on Nov 02, 2008
How do i password my internet connection when i have a dynex wireless g router
Choose either WEP or WPA in the internet wireless security area of the router. Then you just set a password and hit apply and you're done!
Mar 04, 2011 | Dynex Wireless-G Broadband Router
How to change the settings on my dynex g router
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 03, 2011 | Dynex Wireless-G Broadband Router
The installation wizard is not recognizing the router. When plugged into the modem, the internet is fine. No firewalls are blocking the router. Tried different hardware cords, did not fix the problem. ...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 27, 2010 | Dynex Enhanced-G Wireless Broadband Router
Need disc for dynex dx-wegrtr
You can confiure your without disk too .
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 07, 2010 | Dynex Enhanced-G Wireless Broadband Router
Router stopped working
check the power adopter and and also check your router's power led is glowing or not, if both are ok then need to check your internet service provider about internet connection.
Mar 04, 2010 | Dynex Enhanced-G Wireless Broadband Router
How do you hook up a dynex 802.11g wireless router
To setup your Dynex router you can follow the below steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.0.1 and then type the username as "admin" and the password is blank so leave the password box as blank
  5. You need to set it up as per your internet service provider if you do not have any fixed IP address provided by ISP then select dynamic IP address and then click on clone mac address after saving these settings on the router setup page you can check if you are able to access internet then you can do the wireless settings
  6. Once the router setup page is open you can confugure the router easily without the CD setup.
  7. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  8. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  9. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  10. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  11. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
Dec 03, 2009 | Computers & Internet
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
check the configuration of the router then re-configur the router it
Feb 26, 2009 | Dynex Wireless-G Broadband Router
Need help with best connection type for college student in dorm
The enhaced version just give more range of signal over the normal dynex, regarding the internet provider it depends because sometimes you'll need a password and user to connect to the wireless signal. The dynex is used to connect from a cable signal (RJ-45)internet and then it will transfer the connection to wireless so it can be use from any laptop with wireless connection. So for example you DSL internet connection is a cable (RJ-45) then you connect that cable to the dynex router, then the router will automatically transmit the signal to wireless so any nearby pc can connect to it. If the laptop doesn't have wireless, then you'll have to buy a card to be able to connect to wireless signal or you could by also a (RJ-45 straight-through cable Cat 5e) to connect from one of the ports from the DYNEX to the laptop. Hope it helps.
Aug 19, 2008 | Microsoft Xbox 360 Console
Need help
You are losing your internet connection because of interference with the wireless router and cordless phone. Try either switching the channel on your router or on your phone. That should fix your problem.
Apr 15, 2008 | Dynex Enhanced-G Wireless Broadband Router
Computers & Internet Logo
David Payne
David Payne
