Question about Canon S520 InkJet Photo Printer
Black jet not printing
I'm having trouble getting the black jet to print. The other colors are fine. I've aligned the print head, cleaned, deep cleaned, and done a nozzle check. The ink level is full and I've made sure the head is properly seated.
  • 1 more comment
  • JimPitt Apr 13, 2008
    I had a similar problem with the black ink not fully printing. I installed a new driver from the Canon USA web site for my Windows 98 system and it solved my problem. I don't know why it worked, but it did. Thanks.
  • Anonymous May 09, 2008
    Oddly, my S520 doesn't even know that I took the black ink cartridge out! It thinks every this fine, and runs a sheet through, but it comes out blank (except for colors).
  • Anonymous May 14, 2008
    cartrige is full but still won't print in black....the machine says it is full but no change.....
    how much does a new driver cost?
    President:
  • Canon Master
  • 2,022 Answers
Re-install the driver and see. bye
Posted on Sep 24, 2007
SOURCE:
Epson picturemate photos printing all black
Maybe you set printer options to print color as black.
Aug 18, 2012 | Epson PictureMate InkJet Photo Printer
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Won't print in black.Colour is fine though!
your printer black cartridge is demage buy a new one
Jul 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Janky printer
Please click here and follow the steps to resolve the issue. Though it shows different product the trouble shooting steps remains same.
May 21, 2009 | Office Equipment & Supplies
My Canon S750 Bubble Jet Printer does not print with black ink. It seems to print all other colors though.
Replace and install the black ink cartridge with this Black Ink Tank BCI-3eBK Ifyou have done this and is still missing the black ink on print, clean the print heads. 1. Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'. 3. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
That should most likely work. If deep cleaning did not help, you may need to replace the print head.
Nov 25, 2008 | Office Equipment & Supplies
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
132 people viewed this question
Clive
Clive
old marine
old marine
