Question about Fisher and Paykel GWL11 Top Load Washer
Agitator flutes are breaking off
The bottom parts of the agitator are getting ready to break off. I believe it might be called the flutes. All three are almost completely torn off.
    President:
  • Fisher and P... Master
  • 2,651 Answers
The agitator can be removed easily, remove the center fabric softener cup and down the center of the agitiator shaft is a wing nout you can remove by hand, simply remove agitator and replace with a new one. call F&P for the replacemnt part
Posted on Nov 02, 2008
Cannot remove top agitator from bottom agitator on whirlpool ultimate care 2
Easy once you have removed the agitator put both feet on either sides. In other words hold it down and pull. The factory tabs needs to be broken. If that fails used a long screw driver and try and break off the tabs.
Apr 28, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
My GE wjre5550h1ww waher makes a continuos loud clank/bang noise when time the washer is in the soak/agitator cycle. Rinse and spine cycle, normal noise/sound. Please help! Thanks
The part (it has three prongs) that the transmission (yes your washing machine has a transmission) uses to cause the reciprocating motion of agitation has broken off 1 or 2 of the 3 prongs, and, if you
continue to use the washer (you might as well, the part is broken already - you may as well run it until it dies), the part will break completely, and you'll lose the soak/agitator cycle altogether.
FIX: replace the broken 3-prong plate, and give it a nice coating of automotive bearing grease to help it last for awhile (until the next thing breaks).
Dec 11, 2010 | GE WBSR3140DW Top Load Washer
Get agitator out without breaking it
Take the head of the agitator off, It unscrews. Once it;s off look down inside there at the very bottom. You will see a bolt, this bolt comes out which hold your agitator in. Once this is removed, the agitator is easy to get out. This will be where the agitator dogs are. Mostly worn.
Feb 11, 2010 | Washing Machines
How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
Agitator has large break in it would like to take
Take the cap off with a screwdriver, then remove the bolt and pull the agitator out. Replace with one exactly like it.
Jul 14, 2009 | Maytag MAV6200 Top Load Washer
Agitator not turning properly
If you are talking about the upper part of the agitator, this is a common problem with well used machines.
Little plastic dogs that grab the serrated sides of the agitator wear down the grabbers. Pull of the cap on top of the agitator and then the cup at the bottom of a well inside.. You will see a bolt head, remove it and the upper part of the agitator comes off.
The dogs are about $5 at Sears or other appliance parts store. It is tricky to replace them, so you need an appliance person to describe how to do it, and print you a copy of the parts break down of the agitator for reference, so an appliance store that sells parts is the better place to go. Sears won't help you with it.
If you are not all that handy, I would not recommend you do this. If you don't understand the technique, or able to intuitively figure mechanical things out for yourself, you could be pulling out you hair. If the person who explains how to replace these dogs doesn't mention doing it with the agitator up-side down, then they don't know how to do it either. Good luck, and you will get a great sense of accomplishment if you succeed. If you break one or both of two little plastic tabs that snap the lower part of the upper agitator to the lower part of the agitator, don't worry about it. They just keep things together and the dogs from falling out when you tip the agitator upright again. You can still hold it together with both hands in order to slip in back on the agitator spindle in the washer and bolt in back on without these convenience tabs.
Feb 27, 2009 | Whirlpool LTE5243D Top Load Stacked...
Dual Agitator not working
If the upper portion of the agitator is not working, this is commonly caused by worn agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Yes...there is such a thing. These small plastic pieces have been the source of many trouble calls and only cost a few dollars to replace if you know how to do it. Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for the search criteria and look under the "Agitator Parts" section. The link also give instructions on how to remove the agitator. This is a very simple repair, that only costs a few dollars. If you wish not to order on
line, use the part number provided by the Sears website and go to your nearest appliance parts retailer. This is a common part they will have in their inventory. If you require further assistance, please let me know. I hope this helps you.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Kenmore 70 series washer
pull agitator completely out ..set on floor place feet against bottom and pull top part up sharply..when you get ready to reinstall break tabs off set bottom part back in first and while holding cam in place set top part back in.. may be difficult holding dogs and tabs in but not impossible
Jul 20, 2008 | Kenmore 22422 Top Load Washer
AGITATOR
There is a is a cheap part that fits at the top to make it agitate. Go to your friendly dealer, buy and install. These go frequently.
Apr 28, 2007 | Whirlpool LSW9700P Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
178 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
