Question about Dishwashers
Miele dishwasher - Turbothermic drying spits out water. When you open the door water runs out of the fan vent, whistling noise as it dries.
  • 1 more comment
  • JBaguley Nov 11, 2008
    Mine does eactly the same!!!
  • robav Dec 20, 2008
    I have exactly the same problem with my machine. I'd be interested if you found an answer.
  • June Lawrance
    June Lawrance Nov 25, 2013
    Giving this a go today.... will let you know how we go
I found this elsewhere on the net. Seemed to work for me. You need 2 pairs of hands though 1 to hold things together the other to work the screw driver. Thanks to Peter.
I had the same problem on my Miele Dishwasher. Basically the outlet built into the door gets gummed up. You can access it by undoing the screws around the edge of the inside of the door. This will allow you to release the front door cover from the inner stainless steel cover and there will be the tubes etc. for the front vent. Take them off and you will find them blocked with gunge. Give them a jolly good clean so it allows the condensation to drain back into the machine . You will also find the fan in there as well. Clean all around that as well if it's dirty. Put it all back together and no more gurgling or water on the floor when the doors opened. Hope this helps.
Pete
Peter Jeffries Isle of Wight
Posted on Dec 20, 2008
I am not a plumber but the previous entry from robav was right. I found it pretty easy .
Open the machine and remove the inside cover for the vent. by turning it with a slotted screwdriver. Then take the front off the machine (remove all the screaw around the inside edge of the door). Then take off the front upper panel (more screws the same as before) You then have exposed all the workings of the machine. You will see a black hose running from under the vent unit. Remove this and clean it out with warm water. The  button panel has 2 more screws on each side  and one large retaining screw at the top (above the handle by the door latch) and remove these and you can lift the button console off the door to get at the air vent unit. It is attached by 2 set of wires which control the unit. one of these will unclip quite easily. Do this. You will see 6 brass screws around the edge of the drying unit, undo these and it comes apart and you can reach the other clip to disconnect the wires.  You now havbe the vent unit out of the machine in 2 peices and you can give it a good clean to remove all the gummy stuff (no idea what it is by the way).
Putting it back is easy due to the legnedary attendition to detail that make meile stuff so good.
Screw the 2 halves back together then  there is a seal which you need to make sure is on the inside face of the vent unit, mine was stuck to the door. It can be genlty peeled off then put into the unit.
Reconnect the wires, it is impossible to get the mixed as they have unique attachements.
pop the unit back in and do up the screws in the reverse order you took them out. and hey it works.
enjoy : )
Posted on Mar 15, 2009
    Novelist:
  • 269 Answers
Yup, like the man said. You have the Miele problem.
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
PS: I still have the puddle on the floor, so am trying again only 3 days later! But this has worked several times before.
Posted on Jan 26, 2011
  • mielevictim Jan 30, 2011
    I've had the same problem and just solved it today. In my case the hose itself was not blocked, but the blockage was at the bottom of the fan. I discovered this by blowing in the hose with it connected to the fan and felt an initial resistance as I unblocked the fan drain. I flushed the fan by pooring water in the vapour outlet and quite a lot of dirt came out of the fan drain.
I am lazier than laziness itself. This worked for me: I removed the top panel of the door only, revealing the vent drain behind the plastic guard. Here's the lazy bit, I gently poured some Mr Muscle drain cleaner into the drain hole. It didn't seem to work after five minutes. However it worked its magic overnight and the next morning a normal wash cycle completed with smooth fan operation and no noise came from the fan. Doesn't seem to have melted anything in the pipe and functions normally.
Posted on Nov 29, 2014
Mine was the same as davidagu explained except that to access the screws on the rear of the black fan unit, I had to rotate the vent on the inside of the dishwasher to release the whole unit. Once released I could undo the two halves and clean it out thoroughly. My tubing was not blocked at all. Thanks for all the comments, very helpful.
Posted on Apr 20, 2013
Thanks for all the advice above. With a bit of trial and error and taking the front off the machine twice I\'ve managed to resolve my problem. The main blockage for me was at the base of the tube where it is supposed to drain into the main body of the dishwasher. I found I had to blow / suck water up and down the tube when the base was still connected to the machine. It also helped to open the rinse aid dispenser and use a cocktail stick to clear limescale from the two small holes on the side wall of the dispenser (not obvious!) Fairly horrible but eventually cleared just fine and the noise the fan made has gone completely - it seems that this was caused by it chugging away through trapped water.
Posted on Jan 21, 2013
Door vent spitting water
Sounds like you have the Miele Problem.
The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service, but it is easy to learn to do it yourself. It can be done at home with no added parts. I think it applies to all Miele dishwashers, at least for a number of model years, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk, muck and slop.
Doggone design sucks on an otherwise nice machine!!
Apr 02, 2014 | Miele 24 in. G692SC Plus SS Free-standing...
Miele g665 leaking water from turbothermic vent
I had this happen too. There is a rubber venting tube which runs from the vent on the door to the rinse/powder release pods. This clogs up and the water then comes out when the door opens. If you take off the front panel of the machine (screws are on the sides) it is easy to take off and clean out by running hot water through it, also clean out the line through the release pods .. problem should be solved.
Oct 21, 2011 | Miele 24 in. G665 Built-in Dishwasher
Miele Turbothermic G579SC Dishwasher Intermittent Problem Dishwasher works fine on approximately 30 per cent of times it is used. This percentage seems to be about the same whatever program is selected...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 07, 2011 | Miele Dishwashers
The little vent above the words turbothermic plus is spitting out water during the cycle.
The fan assembly's drainage path is clogged. With time, food residue cloggs up the drainage path, inside the "Turbothermic" fan, and water accumulates during the drying cycle. The control panel, that houses the fan assembly, will need to be removed. Door panels will also need to come off. Unplug wires and drain hose to the fan, and loosen the round fan grill that secures the fan assembly (located inside the door). Take apart the fan assembly; unclogg drainage path and hose; and wash all parts. Re-assemble, install, and plug, the fan assembly, drain hose and door panels. Good Luck.
Oct 27, 2010 | Miele Premier-Plus Built-in Dishwasher
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
I have a Miele G 892 Dishwasher and recently the vent for the Turbotronic drying fan has been sticking in open position at the ned of the cycle. Teh result is the next cycle the vent fills with dirty water...
You'll have to take the door panel apart. There's a small drain hose between the turbothermic unit and the detergent dispenser. It's most likely clogged.
Feb 22, 2010 | Miele G880 Dishwasher
Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Mar 30, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
4,884 people viewed this question
Top Dishwashers Experts
