Question about GE Dryers
Humming but no run - GE Dryers
    Sergeant:
    Champion:
  • 324 Answers
Is the drum free then your motor is probably
bad.
Posted on Nov 02, 2008
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Pump hums
hums as in it did not turn on and pump water or hums like it should be running great?
Rod
US Parts Center
888-521-6183
May 28, 2012 | Jacuzzi Pool & Spa
Running or not central a/c
There is a capacitor in the fan wiring that gives it a kick start. Replace it
May 20, 2012 | Heating & Cooling
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Washer did not spin out message E20 appeared on panel. Attempts to start just humming noise.
is the humming comming from the motror trying to run or is it just a humming sound if the machine has washed correctly upto that point then check water pump for faults and or blockage machine will not advance if water trapped in machine the humming sound could be the water pump either free spinning indicating a blockage or humming as it is trying to run indicating a faulty pump
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Frigidaire ATF6000ES Front Load Washer
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
Speaker a and b have humming noise
If it's a loud 60 cycle hum stop running it and have it serviced. This hum can be a shorted output which can send out 50 to 60 volts out to your speakers damaging them.
Jul 17, 2009 | Audio Players & Recorders
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Dec 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Dryers Logo
49 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
