Question about Technics Audio Players & Recorders
Technics SU-Z22 fails to turn on. There is mains supply to the tx There is no visible power supply fuse or fuse resistor
  • unclejames50 Nov 02, 2008
    We have checked as advised and without speakers connected. we find there is no voltage to the main board from the tx.
    There are no visible fuses.
    We request that you supply us a circuit diagram showing voltages etc.
    We will then have a clear picture which should enable us
    to trace the fault
    Thankyou
    It looks as though we now have the necessary information to effect repair. We should be right now thankyou.
    However, if not, we will get back with it
    Thankyou for your fast and proficient service.
    Congratulations on a excellent product
  • 89 Answers
  • Pritish Singh Nov 02, 2008
    happy to help you at any time!
  • andrew clarke Sep 25, 2011
    hi im having the same problem wi my su-z22 but as im not technical so the plans dont mean anything to me can u help
  • 1,800 Answers
Check outlet and test cable and voltage transformer also check if there any short circuit
plz do rate this post if u can
Posted on Nov 02, 2008
How do I fix my onkyo tx-sr307
  • Check Fuses
  • Check for failed capacitor or resistor.
  • Check for open solder connection
The thermal cycling of these receivers can result in a failure of the solder joints around the components that get hot. The large capacitors if failing usually show signs of bulging or electrolyte leaking.
When the unit boots up out of standby the unit does a self check to confirm all power supplies are within determined limits. components such as resistors operate near failure limits. These parts are designed to fail similar to a fuse if the circuit is over loaded/heated.
Common problem is the required ventilation is restricted by covering the top etc preventing required air flow, overheats and a safety resistor fails.
Replace resistor with same type to retain saftey features.
Look for a burnt resistor. They are usually raised off of the PC board.
Hope this helps?
Sep 25, 2016 | Onkyo TX-SR307 A/V Receiver
Technics SU-CH900 turn off when the volume up ....
That's usually caused by incorrect loading (eg: 2 ohms on a 4 ohm circuit) or failed components in the power supply or final amplifier stages.
Mar 09, 2015 | Technics Audio Players & Recorders
Technics su-g75 drawing/schematic? when hit power button fuse in power supply blowout.
Fuses blow when there's an overload. This is most likely caused by a semiconductor device(s) shorted. In amps this is often cuased by speaker wires that have touched while on power. The main culprits are the devices on the heat sink. If they are transistors then connecting an Ohm Meter accros the terminals of the transistor(s) (amp switched off) will show as if you have touched the test probes together! More than one device might have blown!!
Dec 23, 2014 | Technics Audio Players & Recorders
Technics SU-G75 has no sound
Hello
when the resistors are burned,means that the transistors are damaged, or the power module is damaged.
and in your case its the power module.
Hope this helps.
Feb 07, 2014 | Technics SU-G75 Amplifier
Technics su v2 amp will not turn on, other components work fine (turntable, radio, cassette player, speakers). I think it maybe the power supply. Tip? Opinions?
Check inside power supply fuse, it may be just that but if you put a new fuse and blows you may have a power output devices failure, let me know your results.
Oct 03, 2013 | Audio Players & Recorders
What is the value of resistor R451 in Technics amplifier SU-Z25
If you are in the power supply, are you sure that one is used? 4xx series are power supply designations. Maybe numbers got transposed?
2 ways to approach it.
I am looking at an SUZ22 and an SUZ55, the power supplies are roughly the same. The closest component is R416 which is a 39 Ohm resistor. This supplies power to the flourescent display in a current limitng mode.
The alternate approach is where is it in the circuit? what is "downstream of it"?
If it was a larger 1 Watt or 2 Watt Try 1500 Ohms.
If it is the flourescent display, 39 ohms is most probable for manufacturer inventory purposes. If LCD, try 390.
If the preamp is downstream, it is not going to require a great deal of power, and you may be able to trace a parallel trace off the other channel to a corresponding resistor. If that has been tried and it just traces back to the same point, Try 1500 Ohms.
Also, there is symetry in the amplifier because it uses a split supply Vcc- and Vcc+ Not to mentione the symetry between right and left channels.
Jul 05, 2012 | Technics Audio Players & Recorders
I have a Technics Stereo graphic equalizer. Trying to find out why it's not getting any power. it has no fuse inside. I hook the plug into the outlet and nothing. atleast the light on the equalizer does...
The power supply unit has failed in your equaliser. If it is the main transformer check for the continuity of the primary and if open you will need to replace with the same one or rewind with the same parameter.However if the thermal fuse is blown you can short the winding with a fuse wire. Also check on the dc side for any fusible resistors that would have opened out. Hope you check this out. Good day
Aug 03, 2010 | Technics SH-GE90 Home Equalizer
Technics SU-Z25 ''no front led's lit'' and no power to the power on led. All other functions are perfect. Please can anyone advise.
Hi and welcome to FixYa,
Check diode D407, resistor R405 and capacitor C403 in the power supply section.
Good luck and thank you for asking FixYa.
Apr 11, 2010 | Technics Audio Players & Recorders
When i turn up the amp the 'current drive' cuts
Check all your wiring for short circuits, check your speaker coils are not shorted either - if you cant do this try any other pair of speakers on the system.
check the main capacitors in the power supply, check the internal fuses, and change the wall plug fuse - check all the large capacitors for closed/short circuit or cracked solder joints, resolder anything suspicious looking. the fuse could be **nearly** blown, and bend apart when it gets warm, change it to be sure... hope this helps.
Jan 25, 2010 | Technics Audio Players & Recorders
My technics su-a900 mk2 keeps blowing the internal fuse
Sorry but it sounds like a problem with the power supply unit.
Look for any 'burnt looking' resistors on the printed circuit board and that should give you a major clue!!
Nov 22, 2008 | Technics Audio Players & Recorders
761 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
