Question about Nikon Coolpix 4600 Digital Camera
Camera won't turn on
My camera also died while it was plugged into the computer and it won't turn on now that I changed the batteries.
    Genius:
  • 2,985 Answers
Check this one with Nikon Support
Posted on Sep 22, 2007
SOURCE:
Sony Cybershot DSC-W180 won't turn on when plugged into computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 27, 2012 | Sony Cybershot DSC-W180 10.1MP Digital...
Camera won't turn on when plugged into Mac to download photos.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Feb 22, 2012 | Cameras
Camera will not turn ON. I changed the batteries but still no change.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
Trying to transfer pictures to computer. With camera turned off I plug in the kodak usb cable, then try to turn camera back on. Camera will not turn on. Battery is charged.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 12, 2011 | Kodak Easyshare M381 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
I had connected the camera to my computer to view my photos, and the camera locked up. The screen shows 59% and won't change. I can't turn the camera off either. Help! I don't want to lose my pix or the...
Disconnect the camera from the computer then remove the batteries.
To download your pictures, try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 28, 2011 | GE Create Leather Jason Wu Digital Camera
My camera is plugged into the computer via a usb cable it has no batteries in the camera should the camera still turn on or does it need batteries in
The camera needs batteries to operate.
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Sep 15, 2010 | Samsung Digimax D73 Digital Camera
When I hook the USB cable to the computer I can't get the camera to turn on so that I can download the pictures and I changed the batteries.
Aug 26, 2010 | Kodak EasyShare C653 Digital Camera
My camera stopped working after downloading pictures
Do you think since the camera was plugged in so long that your battery may have died.
May 18, 2017 | Cameras
No response
Dec 11, 2007 | Pentax Optio E10 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
