Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
There is power to the dryer, but it won't start. I have held the start button in made sure the door was shut, tried different settings... help me please!
  • tybran Mar 14, 2009
    When I press the start button it beeps once and the sensing light comes on. And then nothing. Please help. Rebecca
  • mike martinez
    mike martinez Dec 06, 2017
    I have the same problem. any help or suggestions?
Whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Posted on Oct 25, 2009
THERE IS POWER BUT THE CONTROL LOCK LIGHT IS ON.
Posted on Oct 07, 2011
My circuit board had a burnt solder dot and the motor relay, I cleaned it up and re-soldered and it works great whirlpool duet dryer won't start - 9_24_2012_8_49_03_pm.jpg
Posted on Sep 24, 2012
  • gonewacky
    gonewacky Sep 24, 2012
    At the motor relay, not "and the relay", sorry
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
Dryer wont start
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details. Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Amana Dryers
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Maytag epic Z dryer. I hear rapid beeps when I press the start button and it won't start, no matter what setting I try. The door is firmly shut and the lint tray is clean.
heatman101
May 20, 2011 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
14,155 people viewed this question
Dan Webster
Dan Webster
Sal De
