I recently turned on my monitor and for some reason there is no red value. every thing that should be red is yellow. I've tried to adjust the values on the monitor itself, and also on the video card. I have also plugged the monitor into another pc with the same results. Any help would be grealy appreciated. Thanks
-   I have the same problem with no red value being shown on the M992 which worked flawlessly for about 6 years and then suddenly lost the red value. Who repairs these things in the NYC/Queens area? My efforts to find a repair center in the Queens/Long Island area have come up with no viable options.-   gmvgmvgmv
Check the pins at the end of the VGA adapter of the monitor (this is the cord that plugs the monitor into the computer). One of these pins may be bent and may not by connecting properly to your video card. You can use a very small flat head screw driver (such as one from an eye-glass repair kit) to bend back into place.
If all the pins appear fine, then there may be something wrong internally with the device and it should be sent in for repair.
what brand is this monitor btw??
is this a CRT of LCD display?
this is one of the most common probs with CRT monitors. loose connections are common. try whacking the monitor to see if this has an effect.
similar problem to the gateway fpd1530 monitor displaying for a second and then going to a black...
(More)
similar problem to the gateway fpd1530 monitor displaying for a second and then going to a black screen with the green power light on. The only difference is that it is completely black, no outline of desktop and does not show up when a flashlight is shined on it. Just wondering if it was a different problem from the other ones listed and if it was if there was a different fix for it?
processing Auto configuration keeps shwing up on my screen how do i get rid of it . and the buttons...
(More)
processing Auto configuration keeps shwing up on my screen how do i get rid of it . and the buttons doesnt remove it anymore.
I am trying to get a gateway FPD1530 to work. The unit turns on, backlight stays lit, and the power...
(More)
I am trying to get a gateway FPD1530 to work. The unit turns on, backlight stays lit, and the power light stays solid, but I cannot get any video to display. I can't even use the OSD menu to display. I tested this on several machines, and used several working VGA cables for testing. What can I do to fix this?
on my emachine tha auto process keep popping up on my screen. how do if fix this and what is causing...
(More)
on my emachine tha auto process keep popping up on my screen. how do if fix this and what is causing it????
