Question about Visonik Dual Bass Box with Amplifier Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
I just installed this amplifier Visonik VB212PKG RMS condition is 4ohm - 200 W per channel, 8 ohm - 100 W per channel CONNECTIONS MADE -10 GA power 30A fuse - no capacitor used - GND made & checked - control wire connected from stereo amp control - connected to Low input (from Rear Pre-amp out from stereo) - (18V power verified) - regular stereo speaker connections (8 ohm) per channel - 120 Watt speakers per channel Everything is connected correctly to me. 1. The Red "V" light is lit 2. The GREEN POWER light will not come on. 3. The RED PROTECTION light is lit constantly. 4. The speakers only thump like a heartbeat every one second - with no music sound. What is wrong?
    Problem Solver:
  • 7 Answers
The amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Posted on Nov 02, 2008
Hifonics colossus-ltd dual monoblock amp does not have much output, running a cerwin vega stroker dual 2 ohm sub wired 4 ohm load bridged
Bridge at 4ohms your only getting 600watts rms. You will need to bridge at 1ohm (parallel) and adjust the gain accordingly. This will give it 1600 watts rms. If you would of had a dual 4ohm sub, then you could of bridged it at 2ohms mono, but you can't you have to go either 1 ohm or 4ohm. I believe it's not getting enough power.
May 20, 2012 | Hifonics Colossus-ltd Dual Monoblock 3200w...
I have a plad213 what load impendance am i running it i hook up 2 4ohm speakers in series bridged on that amp and how many watts RMS am i getting per speaker
2 4 ohm speakers wired in series is 8 ohms and then is dropped back down to 4 ohms when you bridge it.
2 4 ohm speakers wired in parallel is 2 ohms then dropped down to 1 ohm when bridged
(most amplifiers will not handle loads below 2 ohms)
hope this info helps
May 20, 2011 | Pyle Dryver PLAD213 Car Audio Amplifier
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
Mar 23, 2011 | Car Audio & Video
How do i hook up my amp. the ground wire and the v 12
well, basically... the 12v (+) power wire is fused and hooked to the battery and ran to the amplifier, then run an amp turn on wire from you radio its usually blue with a white stripe (if you have an after market radio) then run the rcas from the radio to the amp and finally tap the ground (usually and cleaned bare-metal on your car close to the amp).... if you give me some more info i can help u further... what is the make/model/yr of your car, what radio do you have, amp, sub, speakers, etc....?
May 02, 2010 | Visonik VB212PKG Car Audio Amplifier
Amp wont turn on..Visonik vb212pkw
Well you have a high impedance path to your amp. If you have an inline fuse that should have blown. Car batteries don't have a current limiting feature HA The only explanation would be that the amount of current passing through the wire is causing a large voltage drop due to a large impedance. What gauge wire are you using? Here is an example.
18 ft of 8 gauge wire would have to be passing about 400 Amps of DC current to yield a voltage drop of that magnitude. The wire would melt and all hell would break loose. So there has to be a break in your wire somewhere.
Dec 18, 2009 | Visonik VB212PKG Car Audio Amplifier
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
Ppi dcx 1500.1 is it 2 powerful 4 da 12in. L7?
Hello montyski20,
The amp outputs 500 watts RMS into 4ohms, 750 watts RMS into 2ohms and 1000 RMS into 1ohm.
The L7 can handle 750 watts RMS (375 watts per each coil). If your L7 is the 2ohm version, you should wire the voice coils in series, the positive marked coil to the negative unmarked coil. Then connect the remaining positive and negative to the amp terminals. This gives you a 4ohm load (500 watts). If your L7 is the 4ohm version, wire the voice coils in parallel, both marked and unmarked positives together, likewise both negatives and then to the amp terminals. This gives a 2ohm load (750 watts).
Paralleling the 2ohm sub will result in a 1ohm load (1000 watts) and that is too much for the L7.
Hope this helps.
Aug 02, 2009 | PPI DCX-1500.1 Car Audio Amplifier
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
NEW AMPLIFIER WILL NOT LIGHT UP OR POWER UP
It sounds like your saying that you have two identical amp, that both are on the same power wires and remote wires and sam grounds? Well if thats the case then you did ok as One amp sounds like its blown. First tghing is check the main fuse. If its good and the unit still dosent resond then the power supply in the amp is blown as theres a switching supply that increases the 12 volts to get power to drive the Mosfet output devices. Was it ever working?? yes then the amp needs service. Do you know how to work on solid state elctronics down to componet level?? No?? Ok contact these folks at the addy im posting for you or take the amp to your local servicer. Good Luck. AudioSupport@VisonikCarAudio.com
May 07, 2006 | Visonik VB212PKG Car Audio Amplifier
Visonik Dual Bass Box with Amplifier Car Audio Amplifier Logo
285 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
