Question about Onkyo TX-DS575 Receiver
No audio After years of using my onkyo receiver with no problems one day I turned it on and I got no audio.... I was afraid I disconnected something but nothing was wrong with my setup because I switched everything to my Sony receiver and everything sounds perfect.... I would like to get this receiver working again and I was told it might be a fuse..... but I only have found one fuse in the entire board and that fuse is fine...... Just for more information, everything seems like it is working fine it is just silent no static no feedback nothing.
Is there a coherent solution for this problem?
Posted on Feb 27, 2007
  • 3 Answers
Cpu mpd720208 send comand -mute- all the time pin 42 AMUT. if you cut this wire, after receiver is on, saund appiar. this is not right, but this work. if you cut this wire in off condition, receiver dont on. i dont find the rison of this, but i think some input voltage for CPU is on the edge. or on-delay cicuits dont work properly.
Posted on Feb 08, 2007
My Onkyo TX-NR838 switches off when I turn the tv off. I can't switch the receiver back on for 2 days
sounds like a faulty cable or psu .... or some bad solders on the back of a scart socket if you use scart
if not its something to do with TV detection the TX-NR unit uses
Dec 04, 2014 | Onkyo 7.2 Channel Network A/V Receiver -...
Onkyo HT-RC360 The receiver has a clicking sound when powered on. then turns off
No! I'am afraid not, if you have checked your wires carefully and it checked, the audio output semiconductors will require a technician to remedy the problem.
Apr 01, 2012 | Onkyo Audio Players & Recorders
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SV444 problem
the shorted spkr wires probably fried the putput transistors in that channel.  Do you know how to use a Fluke  test meter on diode test
Dec 31, 2008 | Onkyo TX-SV454 Receiver
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Dec 29, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Jan 04, 2008 | Onkyo TX-SR605 Receiver
No audio coming from my receiver
my speakers call creative on my computer wont work they use to,i hear sound but not audible
Aug 12, 2007 | Onkyo TX-NR1000 Receiver
Onkyo TX-DS575 Receiver Logo
230 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
