Replacing drum unit on copier: Sharp SF 2114
I inherited the aforementioned copier.  It was fine for about 3,000 copies and then everything went black and the light for making copies went out.  I purchased a new drum unit, but can't figure out where it goes as it doesn't really look like anything inside the machine.  I can't find any instructions for replacing the drum unit online and nothing came with the unit when it arrived.  HELP!  I need to make copies and would hate to have wasted $170 on something that won't fit (or I can't make fit).
  • 25 Answers
Well, if the light under the glass doesn't come on, that means that black copies can hapen. Nothing to do with the drum or drum unit. Either the lamp burnt or the protecting fuse is blown. If you take out the glass, you can mouve the carriage with the mirrors to the right and you can see the exposure lamp. If it has dark ( like silver) bands on it, the lamp is burnt and its brightness will not be enough to make a copy. CHANGE THE LAMP. If the lamp is ok check the thermic fuse wich is in touch with the lamp carriage, and normaly it burns when taking a lot of copies in one go. The drum is a red cilinder that is in drum unit next to the developer unit where you put the toner. If you open the ma chine you can see it about the midle just above the transfer corona. If you don't get it right i can explain how to change the drum. GOOD LUCK.
Posted on Nov 04, 2008
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
Sharp SF-7320 produces grainy copies
Clean the drum unit seal blade thats leaking or replace it.
Nov 11, 2009 | Office Equipment & Supplies
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
Jul 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Our nonprofit got a sharp sf-2040 donated. It prints a too light of a copy. I tried to replace toner it was full. No keys or directions light up - does it need a new drum or something.....??
There are several solutions to this problem:
1. Adjust the exposure
2. The drum may be out.
3. The developer may be out.
4. Finally, You may need a PM for the copier. (replace the drum, developer, drum blade)
Jun 11, 2009 | Sharp SF 2040 Copier
As the bag of a sharp 2114 error h3
SHARP - 2114 - L8-1 - zero cross signal error
SHARP - 2114 - L8-3 - auto-exposure sensor malfunction
SHARP - 2114 - H2-0 - Fusing unit temperature error
SHARP - 2114 - H3-0 - Overheated fusing unit
SHARP - 2114 - H4-0 - The fusing unit doesn't heat up
SHARP - 2114 - U2-1 - EPROM error
May 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp SF 2114 H-4 Error: Fusing Unit Not Heating
Replace fuser lamp and check the condition of thermistor and rectify.
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Copies come out of machine with huge black smudges
If the smudges are consistent, (roughly the same size and approximately in the same location on the page) it's your drum. If not it's your fuser.
Oct 09, 2017 | Computers & Internet
SHARP SF 2114 DRUM UNIT
you may contact SUPERIOR OFFICE AUTOMATION AT 973-533-6778
Dec 11, 2008 | Office Equipment & Supplies
Sharp sf 2114 too much toner on copies
Sound like you need to have the developer, drum and drum blade replaced, you might want to have a tech look at this.
Hope that helps.
Lbcoaster
Nov 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
338 people viewed this question
jasbo
jasbo
