Question about D-Link AirPlus DI-524 Wireless Router
Setup Wizard won't appear
All the lights are on as they should be after connecting all the wires to the router/computer/modem, but when I get to the step where I enter 192.168.0.1 into the address bar the setup wizard will not appear. What can I do to get my router working? I've done this before and never had this problem.???? When I enter the address 192.168.0.50 I get a long list of Service vendors but not the installatio wizzard. The disk shows the same info as the manual no link to the wizzard. owsmith1@fuse.net
  • 728 Answers
Your computer should already have an IP address and you should not have to type it in. It should be automatic if it is connected to the internet. Try and see if you can log on to the internet. If you can't, then try un-installing and reinstalling the software that came with the router and it should work then.
Posted on Nov 02, 2008
    Master:
  • 505 Answers
First click on Start-Run and type CMD. It will open a black window.
Type IPCONFIG and press Enter. Check the IP Address. If the IP Address is 192.168.0.1 then type
PING 192.168.0.1 and see if you are getting reply.
If you have any security software and firewall, disable them and then check. it should open the router page.
Thanks
  • Indrajit Roy
    Indrajit Roy Nov 02, 2008
    Also make sure the wifi in your computer is on before you are trying the steps.
    Thanks
  • Indrajit Roy
    first coonect your wifi router witjh your laptop with cabke and then go to this link
    http://192.168.0.1
    then type user :admin and password also admin or blank
    then go to dhcp then enbale it with auto .
    then disconnect your cable from laptop.
    then go to my network places then find wireless network then simply conect your network.
    thats it.
  • 13,433 Answers
You need to change your ip into the same iprange manually set your ip to 192.168.0.25 for example and then try again. If you need instructions on how to set your own ip, drop me a comment with the add a comment button and include my nickname (ekse) on the message.
Thanks.
Ekse
Router can't detect wired connection
Try this:
1.turn off power and disconnect all wires and cable to and from modem.
2.re-connect after 2 minutes.
3.do the modem buttons light up, including internet.?
4.now check if you get internet connection. you don;t need the wiz because you are hard wired thru cable from ISP?
GOODLUCK
Jan 24, 2014 | Asus US RT-N65U dualband wirelessn750...
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Is this product compatable with vista? I have had this unit for about 6 years and has been in a closet. Changed my internet service and had this old router. It looks like I have it connected properly, but...
Routers are usually not OS dependable. Which means, yes it is. It is compatible. You need to go inside configuration and make sure your router is picking up IP address from your ISP. This is how to do it:
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down
your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the
WAN port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your
computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router
to boot.
7. Turn on your computer.
8. Verify the link lights on the router. The power light, WAN light, and the LAN light (the port that your computer is
plugged into) should be lit. If not, make sure your computer, modem, and router are powered on and verify the cable
connections are correct.
Now to configure router, do this:
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1). (no parenthesis)
Enter the user name (admin) and your password. Leave the password blank by default.
You may run the setup wizard to quickly setup your router. Click Setup Wizard to launch the wizard.
Click Launch Internet Connection Setup Wizard to begin.
Click Next to continue.
Create a new password and then click Next to continue.
Select your time zone from the drop-down menu and then click Next to continue.
Select the type of Internet connection you use and then click Next to continue.
Your connection is probably Dynamic, meaning your ISP is giving you IP address automatically and it changes. So, choose dynamic, and leave host name, mac address and everything else blank. Save it.
That should do it. You can also proceed to setup your wireless. Make sure you secure it also.
If any questions, let me know!
Aug 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Modem router(quest gateway) works on one computer but won't connect to two other computers. was working on two ,and now only the one wired to it.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
1. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
2. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
3. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
4. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
May 11, 2010 | 2wire (1000-400108-001) Router
Dlink setup wizard problem
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 16, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Router will not see modem
It seems your router is going bad , first thing to do here is to reset the router by pressing the reset button for 30 seconds and after the reset unplug the power of the router for 10 seconds and then if you still have the setup CD for the router just run it to the computer conencted to the router and reconfigure the router back....
Oct 24, 2008 | SonicWALL Computers & Internet
Neatgear WGT624 take over
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 06, 2008 | NetGear WGT624 Wireless Router
Pass word to secure the wireless
  1. Then u have to setup ur router first
  2. Turn off the power on your computer.
  3. Securely connect an end of an Ethernet cable to your computer, as shown.
  4. Securely connect the other end to any of the router's four LAN ports.
  5. Connect a second Ethernet cable from the router's single WAN port to the modem.
  6. Make sure the modem is connected to the jack or cable to the Internet that was set up by your ISP.
  7. Start your network in this order:
    1. Turn the modem power off.
    2. Turn the router power off.
    3. Turn the modem power back on. Wait two minutes until the lights are stable.
    4. Turn the router power back on. Wait one minute until the lights are stable.
    5. Turn the computer power back on.
  8. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online,
  9. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
  10. Click OK. This logs you into the router.
  11. Click Setup Wizard, on the left of the router settings page and set up your router , click wireless tab and setup wireless security for your connection
  12. that would fix your problem..
Nov 20, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Sympatico
  1. Start your network in this order:
  2. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online, for example to http://kbserver.netgear.com.
  3. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
  4. Click OK. This logs you into the router
  5. Click Setup Wizard on the top left corner, Select Yes for the Setup Wizard to detect the type of internet connection and click Next.
  6. The Setup Wizard will detect the type of Internet connection. DSL connections which require a login to connect to the internet will be detected as PPPoE. Click Next
  7. Configure your router with the username and password provided by your ISP and click Apply.
  8. The router will now save these settings. When complete, you can verify whether you are connected to the internet from the Router Status > Maintenance menu.
  9. Verify you have a valid IP address (not-blank / 0.0.0.0) on the Internet Port assigned by your ISP
  10. check if you are able to go online wired..
  11. to setup wireless
  12. Click Wireless Settings under Setup menu.
  13. Under Security Options, Select WEP (Wired Equivalent Privacy)
  14. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  15. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
  16. then check in your w/ls laptop, you would find your w/ls n/w name , try connect to it, enter your key , you would get connected
Nov 16, 2007 | NetGear RangeMax WPN824 Router
NetGear wireless router model wpn 824 v2
    4. Click OK. This logs you into the router.
    5. Click Setup Wizard, on the left of the router settings page and set up your router
    6. that would fix your problem..
Nov 16, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link AirPlus DI-524 Wireless Router Logo
19 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
