Question about Sharp Audio Players & Recorders
I have a Sharp CD-BA2650 3 cd, two tape deck, and radio combo. The Cd turntable sticks when one cd ends and changes to the next. The rotation stops as the motor makes a humming noise, then the lcd says "Error". If I tap or joggle the changer, It will unlock and continue it's rotation until it sticks again, requiring further knocks. Also, when ejecting the cd tray, the tray sticks upon opening requiring manual intervention. Any Idea what parts are malfunctioning and what I can do to replace or repair them?
  • Samhain5 Nov 20, 2008
    Thanks for the assist. While the problem turned out to be the motor turning the belt, This reply made it much easier to locate and get to the blasted thing. Thanks again
    President:
  • 624 Answers
There is a belt inside the cd changer that needs to be replaced. Once yo utake the top off the unit you will need to turn the unit on again and open the try. Once it is open look at the back area where the motor is located and you will find it under a circuit board. You need to lift the motor up by pushing the plastic clips that hold the board in place and pull it up a little and you will see how the belt is on the pully. It is very hard to describe how to do this in a forum like this, but if you are careful you should be able to do this.
The part number for the belt is:
92LBE231616
You can get the belt here:
http://www.fox-international.com/
I hope this helps, if so a FixYa! rating would be appreciated. After all, it is the only reward we get for offering people like yourself this free help.
Let me know if I can be of any more help.
Dave
Posted on Nov 02, 2008
My Dual CS 430 turntable suddenly stopped playing - rest of equipment (radio, CD player, tape deck) okay. Can you help, please?
Amplifiers always take the sound of the turntable via a separate pre-amp from all other systems, such as radio and CD players. This pre-amp can go faulty killing the sound from the turntable only. If the turntable goes through the actions of playing the record, then this is the cause of your trouble.
Sep 20, 2016 | Audio Players & Recorders
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
How to burn a Cd
The Sony MHC-BX2 can record from a CD to a cassette tape. This model doesn't have a CD burner. The manual for the MHC-BX2 is available from Sony support: http://esupport.sony.com/US/p/model-home.pl?mdl=MHCBX2&template_id=1&region_id=1&tab=manuals#/manualsTab . See page 12 of the PDF.
If your unit is a different model, please post a comment with that model number. I wish that I had better news for you.
(on those shelf systems that can burn a CD, place a blank CD-R or CD-RW (if supported) in the disc tray. Use the function button to set the recording source (Phono with the Croseley units). Place the tape to record in the tape deck and press play reach a point a bit before the desired point to start the recording. (Some also will record from the radio, turntable, or other device. Again start the source playing.) Then press CD Record. Press Stop when you want the recording to stop or when one side of the tape/LP is finished. (Some have a Split Track button if you want to identify every track. Press this during the silent period between songs.) Otherwise, you will get one track per side with tapes/LPs.)
Jul 10, 2012 | Sony Audio Players & Recorders
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
ION turntable volume is low when plugged into a receiver.
Either the cartridge has failed, or an internal amp in the record deck has, or despite what you say the receiver has. I will clarify this for you. Magnetic cartridges need a pre-amp before it gets amplified by the pre-amp and power amp of your reciever. If that pre-amp fails you will still hear the low sound from the deck, but all others cd/tape would be normal as they don't go into the deck pre-amp.
All you need to is trace the circuit. Find the magnetic cartridge pre-amp and find where it joins with the pre-amp of the amp! If you stick a screwdriver at that point, you will get a buzz at normal volume on each channel. The cartridge pre-amp has gone if you do get a buzz!
You probably find it's a single IC that's gone, some are prone to static problems.
Jan 01, 2010 | ION Audio iTTUSB Turntable
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
I have a 90's vintage Panasonic radio/cd/tape combo unit that I have enjoyed since new. Recently the multi cd unit quit functioning. That unit is separate from the radio and the model is SL PK345. It will...
No answer after a year? Must be a really complex problem or some geek would know how to fix it!
Actually if you just unsnap the cover over the area where the disc plays (push in the two tabs at the edge and rotate upward) and use a swap damped with alcohol to clean the small plaster laser cover (the small part that jumps up and down) you will be back in business.
Mar 12, 2009 | Panasonic Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
i had the same problem. my brother took it apart and found that the belt that opens the tray was snapped. he bought a new one at radio shack and replaced it. but now there's a new error with no code. so thats as far as i can get you. sorry. =)
Dec 05, 2008 | Audio Players & Recorders
173 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
