Question about Sony KV-35S66 35" TV
Sound but no picture
We recently had a cable guy install a DVR with our tv. It worked great that afternoon. The next morning we turned on the tv and a picture appeared. 10 seconds later the picture shrunk, developed lines horizontally, and moved to the top of the screen until it disappeared. After turning it off and back on it either does the same thing or doesn't show a picture at all. The sound is fine. Cable guy says the signal and DVR are fine. What's wrong...how much to repair?
    President:
  • 3,130 Answers
You have a vertical sweep problem. Since this Sony tv has no user replaceable parts inside of it, your best bet is to call out a pro to assist you in this repair.
Posted on Sep 23, 2006
    Sergeant:
  • 337 Answers
I believe the cable guy is correct and I will suggest you call for professional help now,if you try to use it like this the problem might become expensive.
This only happens in the morning when I get up, the TV will not stay on. When I press the power button it turns on and then shuts off. Sometimes it takes a few times of this before it kicks on but this...
it's almost like it's to cold and needs to warm up or something first, How cold does it get there? I can't imagine it even gets to temps as cold as here. In my experience I've seen T.V's where this has happened and only gotten worse as time went on until one day....It never come on at all. But it wasn't a flat panel either. maybe it's letting you know she's about to kick the bucket. Try warming it up with a hair dryer in the morning first and see if it stays on then, then you'll know at least it temp related. other then that sorry guy
Sep 13, 2011 | Televison & Video
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
I have a 500GB WD My DVR Expander that is connected via an eSATA cable to my Scientific Atlantic Explorer 8300HDC DVR. It was working great for several months, but recently my recordings are bad. The video...
What happens if you move the DVR off your Sony TV and put it onto your wife's TV (swap DVRs). Does the problem follow the DVR?
If it does, then you are looking at something common with the DVR, since the expander appears to work just fine on another dvr. If it problem doesn't follow the DVR when swapped, you may be looking at a ground loop issue.
Ground Loops occur when different devices are plugged in at different points. Ideally, everything should be plugged into the same power strip, or wall outlet. But, when things are plugged into different points, noise can pop up due to the difference of electrical potential on the grounds of the equipment, and even the neutral conductors. This can occur even when using an extension cord that is plugged into the same strip. Also try using a different power strip temporarily to see if that improves things as well.
Sep 02, 2009 | Televison & Video
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I have a 35-inch Mitsubishi TV Model CK-35MX2. It is 15 years old but has never had a problem. Recently, when I first turn it on in the morning, the picture has a vertical roll until it warms up and after...
I have a Mitsubishi  "CS-3515R.  Serial number 528801. When I turn it on by remote or on the set itself, I can hear the power come on.  BUT there is no picture and no sound.  What do I do?
Oct 20, 2008 | Televison & Video
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
PICTURE !
Digital cable source box at fault.
Oct 10, 2007 | Toshiba 20AF46 20" TV
Pioneer 5070HD, Onkyo TX-SR605S receiver and Cyberhome DVR 1500 connection
you may have fixed your dvr1500 by now but i just came across your signal problem today,so if it is still not working try putting a cable from the yellow video out of your 1500 to tv video in ,switch to this input on your tv and you should get a picture.after this is done set output on 1500 to composite and put into cbl/sat on amp,put hdmi cable from tv into hd out on amp, go to setup input assignment ,click on this to get monitor out,click again you get hdmi mntr flick right to switch on,put your tv to hdmi and you should have a picture.
hope this helped.
cable guy.
Sep 17, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Sony KV-35S66 35" TV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
