Question about Acer AL1717 17" LCD Monitor
Power on/off My monitor was working fine, but the computer then wasn't used for a while. Now when I tried to start it up, the monitor won't turn on. No lights, nothing. I know the power cable works fine, just there's something wrong with this monitor.
  • Anonymous Dec 11, 2008
    I have the same exact problem...only 2 year old monitor. The green LED on the power button flashes on & off but thats it.
  • 124 Answers
Hi, Try using another outlet.
Does your AC power cord have any indicator lights which is why you know the power cable works fine?
Base on your assessment, I would say the power supply board on the monitor needs to be replaced.
Mike H.
Posted on Nov 02, 2008
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
My compaq 1725 computer moniter won't turn on when I press the power button. The actual desktop is on and seems fine but the monitor remains dark without even giving the orange light that it used to.
first check the power cable if its properly plugin, and check if ac to dc adaptor has a output power.
you can check it by using digital voltmeter or an analog multimeter, you can see the pin output in the back of the adaptor, it has positive and negative sign.
Aug 14, 2011 | Compaq Presario 1725 Monitor
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
When computer is started no signal appear on the monitor.
If your monitor is working fine, my guess is you might forgot to turn on the monitor power switch which is located at the lower right bottom corner. try it
Sep 13, 2009 | Computers & Internet
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    Monitor will not turn on- was working fine a week ago!
    Replace it as they are so inexpensive.
    Fleabay has a lot of choice.
    Feb 27, 2017 | Acer AL1703 17" LCD Monitor
    Monitor keeps blank even the power lLED is on green
    Try replacin a new display card. If it is fine working.ok
    If not try fixing for cold solder in the video section.
    I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
    Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
    DVI input on monitor not working
    Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
    If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
    Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
    Acer AL1717 17" LCD Monitor Logo
    112 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
