Question about Panasonic PT-52DL10 52" Rear Projection Television
Panasonic 52 in cianema vision how to make second channel appear in corner
  • aishamommand Dec 09, 2008
    my panasonic tv which is 4 years old turned off last night,the power botton is blinking but nothing clicks or shows, can any one tell me how to fix it?
I turned my tv on one day and the screen just went to like times 100 in size so i replaced the bulb not the problem how do i fix it
Posted on Dec 09, 2008
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
Have 52 inch toshiba regza tv black box appeared in top left corner will not go away tried changing channels still there
Check to see if the tv is in the text mode of the closed captioning.If not you may need a new main signal board.Also try unplugging the set for a couple of hours to reset it.
Nov 04, 2009 | Toshiba REGZA 52RV530U LCD TV
My tv appears child lock
well then you will have to take the tv to a fixing place to get the lock removed and then buy a universal remote or find the one you've lost
Sep 02, 2009 | Televison & Video
How do you connect bt vision to a sony bravia kdl 37v4000.I have it working ok on freeview only but the bt vision appears on analogue channel 6 and the vision remote changes the tele channel not the vision...
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Jul 23, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Mits diamond vision 65
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Dec 26, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
TV has no vision , only one channel has sound
your tv is locked!
If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels. • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Dec 21, 2007 | Apex Digital GB4308 43" Rear Projection...
Panasonic PT-52DL10 52" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
