When I turn the tv on the sound is ok but no picture. If I hit the tv on the side the picture comes, sometimes. This problem has been going on for about a year. Now the picture does not come on when I hit it on the side. However, if I let the TV on the picture comes on, anywhere from 15 minutes to two hours. When the pictures comes on, the quality is perfect. Q. Any hints as to why the sound is OK, but no picture when I turn TV on? But if I let TV on it eventually the picture comes on. Any suggestion will be appriciated. Thank you, Alex
The other two solutions prior to mine are retarded!!! I've worked in a Tv repair shop for over a decade and the problem is the same as 99.6 percent of all other electronics that function correctly when you smack them! "BAD SOLDER CONNECTIONS" STEP1, plug-in and turn on the device. DONT BE A CHICKEN SHIT! unless! It's a microwave oven,those can kill you!anyway you need to open up the device,in this case the Tv.plug-in and turn on the device,Find something non-conductive,like the handle of a screwdriver holding it backwards,if you don't understand just use somthing non-metallic like a clean wooden spoon!Anything wood or plastic, then tap around the circuit boards. YOU WILL NOT GET SHOCKED!!! If you use something non-metallic! eventually you will get a response weather it corrects the problem or causes the failure you have located the bad solder connection .STEP2, Now unplug the device from the wall! locate that area on the bottom side of the circuit board and resolder the indavidual solder jonts in that vicinaty more often than not,It's a part that is screwed or clamped on to a metal plate or block. DO NOT SOLDER TWO SEPERATE SOLDER JOINTS TOGETHER! IF YOU DO AND CAN NOT SEPERATE THEM GO TO A RADIOSHACK OR SOMEWHERE AND GET SOME CHEM-WICK OR SOLDER-WICK/DESOLDERING-WICK IT LOOKS LIKE A ROLL OF BRAIDED COPPER WIRES! PUT THAT STUFF BETWEEN THE SOLDERING IRON TIP AND THE CONNECTIONS YOU FUCKED UP! AND IT WILL DESOLDER THEM! IF YOU DESOLDER THEM ALL THE WAY RESOLDER THEM WITHOUT SOLDERING THEM TOGETHER AGAIN! REPEAT STEPS 1 AND 2 UNTILL THE DEVICE NO LONGER FAILS. PRECAUTIONS: 1 ONLY USE A PENCIL-TIP TYPE SOLDERING IRON,2 DONT USE SOLDER THICKER THAN ROUGHLY 2 MILIMETERS OR 1/16 OF AN INCH! THE THINNER THE BETTER! "YOUR WELCOME" FOR MORE HELP YOU CAN REACH ME AT [email protected]
The longer you slap the set silly to make it work, the more the tech will charge you to fix it, as a bad connection can make other parts go bad. so if you continue using the set like it is, it will kjost likly cost you double to repair in the future. now if you do not plan on investing anything into this set, then go ahead and use it as is , but I must warn you , a bad connection is the right area of a TV set canm cause severe heating up of the connection, and that can lead to fires!
The good thing is the set reacts when you hit it in side,the two symptoms are related and I will suggest to call for professional help now and the repair will not be as expensive as if you try to use it like that.
i turn on my tv and it has sound and a picture but it went out with no picture sp i hit the side of the tv it went on then it had a picture 4 about a hour then it went out and i try to hit the tv but it would come on and it make a sound went it go plz help me out.
I have no picture but good sound i have a totally black screen except for the line of color through the middle.
i have perfect sound, but no picture. it did this once before, and the picture came on after a while, but now, it doesn't come on at all
I have the same problem but slapping doesnt works for me. i press input or pip/pop button several times to make it work. but now even that doesnt work. sometimes when i switch on the tv , it works fine and sometimes it doesnt.
