Question about Dell Dimension 2400 PC Desktop
USB Header Installing a internal Flash Drive Reader. My Dell Dimension 2400 only has one USB Header port. How can I have both plugs plugged in to the mother board if there is only one port?
  • 2slim Dec 17, 2008
    I want to install an internal reader/writer in my 2004 model Dimensio 2400 and it has only one hearder port for the front. Since the device I want to install has USB ports, why can't I simply unplug the original ones from the MB?
    Scholar:
  • 89 Answers
Can't. If you only have one USB header and have front USB attached and want to add another USB device, you'll need to add a USB card with an internal header. This may be a good one for you: http://www.newegg.com/Product/Product.aspx?Item=N82E16815124008
Thanks
Posted on Nov 02, 2008
  • Dell Master
  • 4,338 Answers
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dell dimension 2400 usb not working
Hello.
Your Dell has two front-panel and four back-panel USB 2.0 ports.
If NONE of the USB ports are working (and I'm figuring that you have tried other USB devices to eliminate a faulty USB device), this is usually caused by a drive letter conflict. The best way to resolve it is to remove all USB devices, then uninstall the USB controllers and hubs from Device Manager, then reboot and allow your controllers/hubs to reinstall.
If still a problem, use disk management to assign higher drive letters to the existing devices. For example, a permanently connected external hard drive and card reader can be set to V and W. Generally, newly connected flash drives will take the next available letter.
Hope this helps.
Jun 30, 2010 | Computers & Internet
I have a dell dimesion 2400. the usb ports will not work. What do you suggest i do o fix this problem
1. Usually this is a setting in the BIOS (Basic input/out systems) which enables the usb ports. Sometimes a firmware upgrade from the manufacturers web site will resolve this issue. WWW.dell.com ( support).
2. This could be that the usb port have been shorted out. This will require a tech to resolve at the mother board level. Most time this will require a mother board replacement.
Mar 31, 2010 | Dell Dimension 2400 PC Desktop
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
Went to a convention we were supplied with a memory stick of part of the proceedings..have Dell Dimension2400 windows xp sp 3 ,have no idea how to use it please advise
Just plug the flash drive into one of your USB ports and on the lower right hand corner of your screen you should see a balloon that says "USB mass storage device detected." Click on that balloon and it will open the file up.
Nov 01, 2009 | Dell Dimension 2400 PC Desktop
Cant
in jeneral memory card meance card reader ( mobile/d igitalcamer/phone cards where we put photo song.....etc) it is as pen drive device we put data directly in pen drive but in card reader . we put data in memory card through cardreader. both are use in computer usb port. computer dected card reader as apen drive.
are you not saying about ram ? it is also called memory. it is use in mother bord slot. they are white and plastic.
Jul 12, 2009 | Dell Dimension 2400 PC Desktop
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
Imstalling internal card reader
Well, installing an internal card reader without a spot on the motherboard, is a little hard to do. I would suggest buying an external card reader. They are a little cheaper, and a lot easier to setup and use, since they just connect to a USB port which all computers have.
Feb 23, 2008 | Dell Dimension 3100 PC Desktop
Installation help for dynex dx-crd12 all in one card reader
I would recomend installing the card reader this way. Shut off all programs that you don't need during the start up. When the card reader installs its kind of touchy, froze my computer a few times.
If you have blue 9 pin usb headers on your motherboard, consult your manual for this, or google it. Take the 5 pin connector, find the side with the red wire, face that side away from the side of the blue header with a missing pin. Make sure you connected to the row with 5 pins. After that you should be able to power up your computer and it will work.
If your computer doesn't reconize the card reader use the cd it came with.
Nov 10, 2007 | Electronics - Others
Dell Dimension 9100 PC Desktop problem
I'm not sure where the floppy drive comes in, but if you have usb connectors on your mobo then you can connect the 5 pin connector to half of the usb pins.  Try that and see what happens.
Oct 25, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 2400 PC Desktop Logo
109 people viewed this question
Alun Cox
