IBM pc won't go past logo screen.
I have checked in the bios screen and all of the drives are detected. Why won't it boot. All of the power cables are connected. I put in the XP cd and changed the boot order to the dvd but I still get the "system starting" screen.
tim
  • 1 more comment
  • tnbrennan Nov 02, 2008
    I have restored defaults,pressing F8 does nothing.
    tim
  • tnbrennan Nov 04, 2008
    The disk is a genuine xp upgrade.
  • notary_sojac Jan 12, 2009
    We have the same problem suddenly with one of our M42s. It will not get past the logo screen displaying "System Starting" with a boot CD (WinXP shrinkwrap CD, BART, etc) or WinXP HDs that work fine in other identical M42s.
    BIOS was reset to defaults, CMOS battery replced, keyboard and mouse swapped for ones that work fine with other M42s...
    All had booted fine with a BART CD when it was imaged them several days ago, and from their HDs when we were configuring it. We drove them to their new home and all started up fine except for this one. I suspect something broke in transit on the mobo as all cables are solidly in place.
  • 94 Answers
At startup press f8 key and last known good configuration
Posted on Nov 02, 2008
    Scholar:
  • 195 Answers
Go back and reset your BIOS to default, when the system startup screen comes on, press the appropriate F-Key. at the bottom of the screen, you will get an option to Restore Defaults, Exit and Save. Take it and Reboot. Good Luck.
  • Rick Drew Nov 02, 2008
    Tim, the only other solutions is that your windows on the disk is not a bootable disk, in other words if it was downloaded from the net and then put to a CD it wasn't made a bootable disk. The only solution for that would be to install windows by clicking on your CD drive, but you can't even get the computer to recognize you have a hard disk. So that means just that, You don't have a system on your computer to read which comes from windows. Do you have another copy of windows on a disk you can install? it doesn't matter which windows as long as it is a bootable disk. You can always upgrade after you get some type of windows on your disk. Good Luck.
  • Rick Drew Nov 04, 2008
    Okay Tim, I got what you need, Just recieved the software for my personal use because what happened to you can happen to anybody. Scarry Huh? I need your e-mail again, and I WANT that I fixed ya rating. (Smile) What DOS and WHAT WINDOWS do you have Installed?
Acer aspire one netbook won't go past acer logo screen keeps saying check cable connection no bootable device
Your laptop is trying to boot from network. Pressing the del key after turn the laptop one, access to bios and change the boot order. Hdd should be in first place.
Oct 22, 2012 | Computers & Internet
When a SATA CD/DVD-ROM Drive is removed, the system fails to boot! Crazy! I just used the drive to re-load the machine but has to remove it. The moment it is removed, the machine fails to boot pas the...
Hi.
Go into the BIOS and set the BIOS configuration to its default settings. Save the changes and exit the BIOS.
When the computer restarts see if it will boot past the Windows logo.
Please let me know what happens.
Good luck.
Jun 09, 2011 | IBM ThinkCentre M50 8187 Desktop PC -...
IBM Thinkpad x41 tablet does not go past the ibm boot logo at startup. BIOS does not open or any of the other options at startup. What should i do ?
If you have the machine on a dock of any sort, remove it from the dock.
If that doesn't help, try taking out the hard drive. See:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-54584
for instructions.
If you get past that screen, put the hard drive back in. If you're stuck in the same place, you may have a bad drive. If it boots. . .great!
Feb 21, 2011 | IBM Lenovo ThinkPad X41 Motherboard...
Have an older T23 IBM Thinkpad. Was running Malwarebyts which I just loaded on the system due to a problem at work and wonted to make sure i was ok at home. System ran for aprox 32 min and apeard to lock...
This is a possibility, the T23 is a very old laptop.
Normal 0 Check the BIOS to see if the hard disk is detected, if not open then re-seat the hard drive.
If the BIOS does not detect this hard drive, then the hard drive is probably faulty.
If it was me, I would not waste my time and money trying to get a new hard drive for this ThinkPad.
Disk drive manufacturers do not make small capacity hard drive anymore and the current range of hard drives won't work in your ThinkPad because the BIOS cannot support these hard drives.
Oct 02, 2010 | IBM ThinkPad T40 2373 Notebook
Wounlt go past IBM logo and cant access F1 or F12
Did you check the fans to see if the unit is overheating?
Clean out all ducts and airways from the fans and try this again. Write back to me with your results.
Mar 15, 2010 | IBM ThinkCenter M50 (8189A1UJ) PC Desktop
I have a compac computer with uwave motherboard it says it cant find hard drive whenteyin to turn on
First open cpu cabinet.
Then disconnect power cable and sata or ide cable from harddiks then connect agagin.
Also check your ide or sata cable which connect to hdd works fine.
Refix your RAM memory to.
Then when you power up the computer press F! or F2 or "del" key to enter in bios.
Then check in bios that your hdd is detected?
Then if detected set first boot device in boot optionj in hdd then check.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Compaq Presario 5000 PC Desktop
Hi, pc doesn't load bios
Hey just remove the hard disk and and removable drive and then try.
And check that your hard disk data cable and cd/dvd driver data cable is in good position or not. Many times the problem is happens because of cable. So you just try a new cable.
Mar 09, 2009 | Intel D915GEV Motherboard
IBM T30 2366-FBU, will not boot passed Logo screen
Press all of the function buttons one at a time until you get a response. Not all laptops use the same buttons for Bios and choosing the boot device.
Also, it won't boot from the CD-ROM because the bios boots from the Hard drive first by default. You can change this in the BIOS.
Please rate, Thanks!
Feb 27, 2009 | IBM ThinkPad T30 2366 Notebook
Password
Set the BIOS to boot a floppy first, see if you can load a boot floppy. If not, then you have a serious hardware problem, did you change any settings in the BIOS? You may need to bring it to a shop for service. If you are able to boot, then you have a hard drive problem. Check your detection settings, and download and run a drive diagnostic tool from the hard drive manufacturer to see if the drive has failed. It wouldn't hurt to reseat the cabling either.
Mar 08, 2006 | IBM ThinkPad 600 Notebook
Computers & Internet Logo
332 people viewed this question
David Payne
David Payne
