Question about Whirlpool Dryers
Gas Dryer Problem
I have a Kirkland by whirlpool gas dryer model # SGDS800JQ1 and I think the burner is not working properly. My husband changed the igniter and the flame sensor. That did not resolve the issue. The dryer turns on and everything works but the flame only turns on for approximately 3 to 5 minutes, after this time the dryer gets hot and then it turns off. The igniter turns on for about 5 seconds but no flame is visible. The igniter keeps turning on every minute or so, sometimes we can smell gas. My husband checked the omes for both thermostats, the fuse and the coils they seem to be OK. He does not know what else to try. Please help asap. Thanks
  • alexanderosc Nov 11, 2008
    Thank you for your prompt response. I changed the coils as you recommended and my dryer is working now. You are a lifesaver!
    Sergeant:
    Champion:
  • 324 Answers
I would change both coils anyways,they can go bad after they heat up.
Posted on Nov 02, 2008
I HAVE A KENMORE DRYER, MODEL # 110.78652700 AND THE BURNER DOES NOT IGNITE. DRUM TURNS BUT NO IGNITION. ANY IDEAS?
check to see if the ignitor is lighting,, if it is,, then you need the coils replaced, on the burner control,, this link shows where they are http://www.applianceblog.com/mainforums/sears-kenmore/17748-kirkland-gas-dryer-no-heat.html if the ignitor isn't glowing,, replace it
Aug 22, 2011 | Dryers
When i turn the dryer on the burner does not ignite and no heat inside the dryer model #LG501XTW1/serial #MB3709493
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 17, 2011 | Whirlpool Dryers
I have a whirlpool duet gas dryer and the burner turns on for about 2-3 minutes then shuts off for about a minute then cyle repeats itself. Any ideas?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 14, 2010 | Whirlpool GGW9200L Gas Dryer
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
Whirlpool gas dryer model#LG5791XM- the burner is working off&on
first check to make sure the venting isn't blocked by lint. second, check the igniter, if it is orange in color you need to replace it, it should glow white.
Nov 14, 2009 | Whirlpool Dryers
I have a kirkland by whirlpool gas dryer that wont heat, any suggestions,all it seems to do is tumble
First, check the ignitor. If it is working properly it should glow noticeably. If the ignitor is working and the burner will not light, I would look at the gas valve coils. These small black electrical coils are right above the gas valves. These solenoids open the gas valves when energized. If faulty, the gas valves are not opened and the burner cannot light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Burner wont light
If you have replaced the igniter and the thermacouple. Your next item is the gas valve. This is not that hard to change out, but is probably the most expensive part on the dryer.
Please rate this solution
Aug 02, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
278 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
