On my JVC DVD player recorder, the laser will not reconize dvd disc.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to replace the lens if theres
is available in the store
Posted on Nov 07, 2008
    Master:
  • 505 Answers
First of all when you insert the DVD is it moving. If its moving and not yet recognising the DVD then get a cd/dvd disk cleaner disk to see if laser lens is dirty and clean it.
Thanks
Posted on Nov 02, 2008
  • Indrajit Roy
    Indrajit Roy Nov 02, 2008
    This could be an allignment problem too. Most of the drives have this prob with no chance of repair. Replacing the lens system will solve them. Sorry!
  • 728 Answers
Try a different disc because the one you are trying to use may be in the wrong format and can not be read by that laser. If that does not work, try blowing on the laser just in case there is dust on or around the laser causing it not to read the disc. If that does not work, you may have to buy a laser cleaner that has a brush on it, and when you insert it, it will clean off the laser and it should work.
Clean ? Repareable ? Trash ? Sell as is?
The laser pickup assembly is shot, over time the laser becomes weaker until it can no longer read the disc,it is time to retire the item, far cheaper to replace the entire unit.
Mar 12, 2012 | JVC DR-MV7 DVD Recorder/VCR
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
Won't detect any discs
The optical laser pickup is fu.k.d up.  You might as well throw away this cheap piece of sh.t and buy you a Sony or Pioneer.  There is a reason why name brand costs a little more- they invest in R&D and product quality testing.
If your handy you can open this puppy up and install a new optical lens, but why bother when you can just go out to the store and pick up a decent DVD player at a reasonable price.
Nov 02, 2009 | Cyberhome DVR 1600 DVD Recorder
DR-MV100B will not read disc
It could be a dirty laser. Try running one of those laser cleaning disks through it. That might help
Sep 22, 2009 | JVC DR-MV100B DVD Recorder/VCR
Jvc dvd player no disc error
Hello!
I did have a similar problem. It was solved by cleaning the laser lenses/prisma. You have to dismantle the whole pick-up the to see the laser lenses.
There is one lens which is held by couple wires and below there is prisma/mirror.
I did use ear-cleaner-stick and desinfection liquid (with alcohol) for cleaning. Now it works!
Aug 16, 2009 | JVC XV-N312S DVD Player
Replacement DVD drive for a JVC-SR-DVM600
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG DVD roms and DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
May 28, 2009 | JVC SR-DVM600
here,s a thought,i know from knowledge of these dvd/dvd prayers.they get hot and the motors sometime burn out in them,could be one problem try cleaning it with a drive cleaning cd and or keepnig it it a cool place,also most of those need to be power with the hdd hi tech cables,not the old fashion kind,good luck.hope i helped
Apr 11, 2009 | JVC SR-DVM600
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Jvc dvd/video recorder
Time for some laser work. You have a disc read error...accordianman
Oct 02, 2007 | GoVideo DVD-VCR Combo
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
