Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Cartridge Replacement I replaced the Black Cartridge but the printer did not ask the usual question "Did you replace the cartridge?" To be answered by Yes or No. So I think the printer did not recognize that I replaced the cartridge. So it still has a warning that the black cartridge is "near empty".
I have the same PB!? . It has a waring all cartridge is "nerar empty".
Posted on Nov 04, 2008
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
Where do I put the replacement cartridges?? I can't see where it goes on this printer???
here is your answer this was found here in your manual if you need it heres a link with picture instructions. start on page 15
MANUAL:
Open the printer, and then press down on the print cartridge carrier levers.
Open the color cartridge foil, and then remove the cartridge from the pack.
Remove the tape from the color print cartridge, insert the cartridge in the right carrier, and then close the color
cartridge lid.
If a black print cartridge is included in the box contents, open the black cartridge foil, and then remove the
Note: You may need to purchase a black print cartridge separately.
14 Remove the tape from the black print cartridge, insert the cartridge in the left cartridge carrier, and then close
the cartridge carrier lid.
Close the printer, and then load plain paper
Mar 26, 2010 | Lexmark X4650 InkJet Printer
I have a Dell 720 printer; just changed the black ink cartridge, with a Dell cartridge. But won't print in black. Colour cartridge working Ok. Have cleaned nozzles, reset printer preferences, dipped...
It is possible that the cartridge that you bought is not working and it happens, I experience it myself. Since you have done most of the troubleshooting for printer cartridge issues, you may want to contact Dell technical support to have that cartridge replaced. They might ask you to do those steps again to validate the replacement.
Mar 20, 2010 | Dell Inkjet 720 Printer
Printer wont print
Turn the printer on. Remove the cartridges. Gently clean the electric contacts on the cartridges and the cartridge carrier. Put the cartridges back in. If the light is still flashing, and your printer won't print, one of your cartridges is faulty. I suggest you go to the refill shop and consult them which cartridges needs a replacement.
Does any message appears on your monitor when you try to print something? Usually, a message saying "problem with black/color cartridge" or something similar, that's why I am asking.
Dec 22, 2009 | HP DeskJet 930c InkJet Printer
Asks me to check catridge on right. Nothing appears wrong and a replacement gives the same problem
if you have replace the black cartridge with an other one and it's still ask you to check right cartridge try cleaning the contacts in the printer that cartridge is resting
Nov 26, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How do i get the cartridge out
Oct 20, 2009 | Epson Stylus C40UX InkJet Printer
My ESP 7 printer will not accept that a new black ink cartridge has been inserted. I've tried 2 new ones, same with both.
Black ink cartridge is not recognized. I installed a new cartridge last week and had no problems printing till 2 days ago. What can I do to resolve this?
Sep 13, 2009 | Office Equipment & Supplies
Cant change ink cartridge on my Epson C91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
May 02, 2009 | Epson Stylus Photo 1400 Printer
How can i print in just black with no color cartrage
in your printer you can use single cartridge but there should be both cartridge inserted in the printer.it will not print if only one cartridge inserted.so let the colour cartridge empty but it should be there in the printer.other wise it will not print.at present the problem in your printer is colour cartridge circuit is got faulty so the printer is not detecting the co,lour cartridge in it.so it ask for replacement.in this case you will have to compulsary get the replacement cartridge.you can buy new cartridge or recycles cartridge that will be quite cheaper then new cartridge.
Apr 03, 2009 | HP PSC 750 All-In-One InkJet Printer
Hi on my hp psc2110 all in one ,I have just replaced an old black ink cartridge with a new one .I have tried several times to print and scan.But the error message :Remove and check right cartridge:still...
most likely some problem with the cartridge itself.
if you are using "aftermarket" cartridges, that is usually why the printer doesnt full recognise it...if using a real hp cartridge, there might be a problem with the little circuit board (that is under the tape strip when new)...try returning it to the store where you bought it and asking for a replacement.
Jul 14, 2008 | Office Equipment & Supplies
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
