Channel 91 say av input
When I turn my RCA television to channel 91 there is a black screen and it say av input. I do not have the original remote control.
  • mlleslie196 Nov 02, 2008
    One of my favorite stations was switched from channel 76 to channel 91, so now when I turn my tv to channel 91 all I get is the black screen with the av input display. I have tried doing the auto search to see if it would pick up the station, but nothing. I am wondering if there is a way to get channel 91 off av input and be able to pick up my station.
    The television is an RCA model #F26050WN. I have discovered that this channel 91 only works on our HDTV. The other TVs in the house that are not HD do not get this station either. Could that be the problem? The station that I am trying to get is Soap Net.
Thanks for all your help. I was afraid the answer might be something like that. I do seem to have a signal issue with the higher channels.
Posted on Nov 03, 2008
  • 124 Answers
Hi , Most older Television allow you to access the AV input line by selection a high channel. That is a normal function on your television. What are you trying to do since you do not have the remote control? Thanks, Mike
Posted on Nov 02, 2008
  • Mike H. Nov 02, 2008
    Hi There,
    Would you provide the brand and model number of your Television.
    Also, I am curious cause switching frequency would not make a difference in the broadcast.. What is the name of that station.
    Mike H
  • Mike H. Nov 03, 2008
    Hi There again,
    Thanks for all the information pertaining to your television.
    Unfortunately, I have bad news. Your Television was design so that channel 91 is a dedicated switch for AV connection ( DVDd or VCR). Unfortunately, there is no way to remove channel 91 so that it can utlize TV tuner rather then AV. I am sorry, I wish I had good news.
    As for the other Television, that is just a signal issue.
    Thet signal is not strong enough under analog broadcast.
    All the best.
Can't get the tv set to video input mode
You may be able to press the channel down button, past channel 1 to the av inputs.
It works on some tvs, but not all.
Aug 27, 2009 | RCA F32632SB 32" TV
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
Universal remote works for basics but won't change input
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
Jan 31, 2009 | Toshiba 32A33 32" TV
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
1992 RCA color trak tv
Rca used channel 91 as the a/v input on my 1990 colortrak,yours should be the same.
Feb 17, 2008 | Televison & Video
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
617 people viewed this question
Top Televison & Video Experts
