Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox push the button nothing happens besides the lights blink
  • 1 more comment
  • rcushing Feb 21, 2009
    I can get the middle two dispensers to work however the top and the bottom only flash red when I hit them - the motor doesn't come on at all
  • pulkowski1 Mar 08, 2009
    the only button that dispenses good is the top slot the bottom one is very weak and the middle two only blink when you touch them. the skybox is located in the garage that is unheated but the temperature ranges for 40 to 80 degrees i'm located in pgh,pa thanks in advance for any help you can give me to help figure this out!
  • firemedic10 Apr 07, 2009
    The lights blink fast when a button is pushed and product is not dispensed.
  • 3 Answers
Problem may be the PCB board (w/Sensor) for the Flipper Door. It has a tendency to become corroded due to condensation that can build up by the door. Maytag replacement part number is 11001182. Part is hard to find. I was able to get one after much searching. Within 3 days it was out of stock again.
To combat the condensation (and ICE build up on the rear main board), turn the fridge down to half and keep the front lights off as much as possible. You may want to play with the settings a little depending on the area of the country you are in (dry Arizona as opposed to wet Washington State) but you shouldn't have to go below half.
Even though the lights are flouresent, they still throw off a lot of heat which causes condensation. The fridge runs longer to combat the heat so the added moisture freezes in the back (where the cooling elements are) and the condensation builds up in the front where the sensor and heat source is. It's cool enough in front to hinder evaporation and because the fridge runs longer you don't get that defrost period (if you will) in the back that regular frost free refrigerators or freezers have, thus the ice build up. This will greatly reduce condensation but may not get rid of it all. The front door is not to well insulated. Hope this helps.
Posted on Nov 13, 2008
SkyBox second button will not dispense
If nothing happens, the switch behind the button must be broken, or something on the PCB that the button is mounted to is broken. But if lights blink, then the button is ok and the problem is with the motor or some sensor. I have a troubleshooting guide for the dispensing system (better than Maytag ever published), as I was directly involved in the design of this product. This does not cover the refridgeration system, as that was provided by our Chinese manufacturer. Please email me at: garymyers@insight.rr.com if anyone wants this guide.
Jan 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't dispense. Door lights on, but no button lights at al
check the unit out to see if its frozen up. there is also sensors that corrode on them due to condensation. if it is frozen just unplug it and let it thaw out.
Dec 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox - Dispense Problem/Lights Flashing
I returned the machine to where I bought it. It not only didn't dispense, it also didn't refrigerate. sorry I don't have an answer for you.
Sep 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
3/4 buttons work
mine did the same thing. apparently, if the internal unit gets too cold, it freezes operation in some of the buttons. try turning up the temp to let it thaw, then try the button again. the downside is that when you turn down the temp again, you are likely going to face the same problem.
Jun 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Cannot get soda to dispense
Sounds like the child lock is turned on. Have you checked that?
Dec 27, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Flashing Lights
I had that problem too, in addition to a backwards cooling fan and the wrong thermostat. I needed to replace a sensor wire in the door, condensation had caused some rust on it.
Al
Aug 26, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
247 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
