Question about Kenmore 63672 Convection/Microwave Oven
Changing oven light
I've tried to figure out how to change the light inside the microwave (not over the stove), by looking at the diagram on the sears.com webpage. The part I bought was WB08X10050, halogen lamp. Near as I can tell, I have to remove the top of the microwave to dig into the area where the lightbulb resides. If so, who designed this so that a lightbulb couldn't easily be changed?
  • 1 more comment
  • mart smith Sep 23, 2006
    I thought I looked in the access panel on the inside (cooking chamber) held in place with a screw, but saw a cooking unit but no bulb. I'll look again to make sure. My model number is 363.63674201. Thanks.
  • Anonymous Nov 15, 2007
    kenmore oven 32363692301, impossible to remove plastic housing unless you vave long phillips with a flexible shaft and pray for a miracle.....a service call is expensive....to replace a bulb. im going to micro in the dark.
    joe
    conine 019@aol.com
  • Tbart19 Jan 26, 2008
    Ok...I actually have both issues. The light inside the oven is out and the light the illuminates over the stove is out.
    So....do I have to take the unit off the wall? Not my forte....that's why I paid to have some guy put it up there to strat with. I can't see any other way to get at the light.
    The light over the range is different. I figured out where that was, opened the cover but the glass broke in the socket when I ent to pull it out. Do I have to undo those &*(@ little nuts that are about 1/100th the size of a normal nut! It looks like from the diagram you provided that the white socket is one piece that extends into the unit. Grrr!
    An help is welcomed in advance.
I have a light bulb in my oven that is frozen, won't come out. The whole unit turns when trying to remove it. Any suggestions?
Posted on Sep 17, 2007
For the Kenmore,
UNPLUG THE UNIT FROM THE WALL!
1. take off the plastic vent grate
2. remove the small black plastic grille behind it
3. lift the metal plate up, reach in and remove the metal bracket that doubles as the lamp housing
4. you can now remove the bulb from the assembly.
5 reverse steps for assembly
Posted on May 21, 2008
  • Kenmore Master
  • 9,098 Answers
If you can post the complete model number, I can pull up the diagram and check for sure, but there are usually two ways to change the inside light bulb: First and foremost, unplug the oven or disconnect it from the AC supply. Failure to do so can damage you or your microwave. On some models, there is an access panel in the rear or inside the cavity (cooking chamber) held in place with a screw. Apparently yours does not have either of these. For other models, you do have to remove the outer wrapper / cover. Quoting my own text "doorsw.txt", here's how: Remove all of the screws from the side and back of the outer wrapper / cover of the microwave. There are usually four on the rear edges and two on the bottom of the edges on each side of the cover. The cover then should be slid slightly backward then up from the rear and it will slide off. You may have to pat down on the sides to loosen it first. I use firm and simultaneous open-palmed slaps on both sides near the front, then pull it up and off. When putting it back on, be careful that the inside front edges of the cover catch properly in the slots in the chassis. Once the cover is off, be careful of sharp edges on the metal inside. Also, do not come into contact with any exposed connections or wiring, since there may possibly be a charge remaining in the high-voltage capacitor. A zap from this charge can be painful, and it can cause you to hurt yourself on those sharp edges when the old reflexes move you abruptly!
Posted on Sep 22, 2006
  • William Miller
    William Miller Nov 11, 2006
    Manufacturers used to include access panels so you can easily change the bulb. Those exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
    You now must generally remove the outer cover to replace the bulb.
    In some over-the-range models, that can mean having to take the oven down from the wall! I suggest a spotter / helper for that task.
    On this model one halogen lamp is goes in the bottom panel to illuminate the cooktop and another illuminates the cavity.
    I have linked below to a diagram which shows it clearly.
    Right about the middle of the page, you'll see the cavity lamp, reference # 282, and its socket, ref# 1207. It mounts in the right front corner of the top (ceiling) of the oven cavity. Ref # 1527 is the glass cover below the lamp.
    Seehttp://tinyurl.com/yccxov
I have the GE JVM1490 Profile Spacemaker. Dr. Ripken's solution works for this oven. You need to remove the front vents, and lift up the plate covering the fan. The bulb housing is bright stainless steel and hinges up and out. The bulb part is the same as the underneath bulb. Unplug the oven before you replace the bulb or you can fry yourself or the control board. nuff said. P.S. I called GE and they said this had to be done by a tech. I guess they are scared of getting sued. -1 for them.
Posted on Oct 02, 2009
4/2008
MicrowaveSvc
Rank:Changing oven light - guru_s.gif Guru
Rating: 87%, 1860 votes
THIS LINK DOES NOT WORK
Posted on Apr 21, 2008
Emerson Microwave MW9325SL
Failed magnetron or power supply.
Aug 12, 2017 | Microwave Ovens
Microwave shut off like it lost power but the receptacle does have power to it. My model is an LVM1750.
The thermal cut out switch in the cavity is bad. I was unable to locate a wiring diagram on the internet but when I took the microwave apart, I found the wiring diagram inside the microwave on the back side of the touch panel.
This unit is mounted above the stove. We were cooking on the stove and also in the microwave. I think there was enough heat to trip the TCO switch.
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light bracket in over the stove ge microwave XL
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 06, 2008 | GE JVM1630 Microwave Oven
How to change light bulb under microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
http://www.microwavedisplay.com
Apr 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Changing oven light
Some models use an tamper-resistant screw which can be removed with a specially-designed tool available from home improvement stores & appliance parts stores.
But some folks just use a hammer to tap and loosen the screw, then a "star", t-type, or small flathead screwdriver can be used to remove the screw.
Sometimes the screws are tough, so you may only be able to just bend the post slightly with a punch, then a small flat blade will "grab" enough to turn the screw. Pliers on the handle will help, too.
Another creative solution is to use a hacksaw or a Dremel tool to carefully cut a slot in the head so a flatblade will fit it.
Jan 02, 2008 | Microwave Ovens
GE JVM1640 Spacemaker Microwave Oven over the stove
You don't. Get service for this. Incorrect installation is dangerous.
Dec 18, 2007 | GE JVM1651 Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Kenmore 63672 Convection/Microwave Oven Logo
2,815 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
