Xp is not loading memory - Computers & Internet
  • 62 Answers
You might not have bought the correct memory. I don't know if you use SDRAM, DDR or DDR-2, but there are different types of RAM within those categories. In SDRAM for example there is ECC and non-ECC. One checks errors, the other not, ALL TYPES OF RAM NEED TO BE THE SAME TYPE ECC OR NON ECC.  Also, you may have three slots that take 528MB max for example, put a 1 GB ram into that slot and it aint gonna work. Please let me know what type of memory you had, put in, and type of computer. You can try going to if you want to check what type of RAM your motherboard (computer part) will take.
hope this helps. post again if you can't figure it out. PS Try computer recyclers for cheaper ram than Frys or Best Buy.
Posted on Nov 02, 2008
Ga-g41m-es2l xp install problem
do you have enough memory (RAM) ? .freezes means to little memory.
Jun 09, 2013 | Computers & Internet
Low virtual memory and slow loading
Go back into the virtual memory settings, change the settings using the custom size adjustment.
Change the initial size to 650 and the maximum size to 1200, make sure nothig else is checked and click set and then ok and exit out of all windows and reboot the mechine. let me know what happens and if the bubble popup disapears. cheers.
Mar 25, 2010 | Computers & Internet
It turns on bot xp dont load and it goes to slepp
if its a loud buzz its probably memory card or memory card slot....which may mean mother board
Dec 10, 2009 | Dell OptiPlex GX280 PC Desktop
Computer restarts on the loading screen.
ITs the problem with the video card and memory, try reseting the memory and install direct X controller and update the video card drivers and then try to install it
Sep 16, 2009 | Computers & Internet
Xp loads and goes black screen
Good day sir/maam, there are several reasons why XP do that,
  1. Bad memory, replace your memory with a good one.
  2. Bad XP installation. you may need to setup your XP again.
  3. Watch your DVD drive, DVD disk installer.
  4. Hard DIsk bad sector. make sure you format the Hard disk as you reinstall the OS.
  5. A bad power supply. If your XP keeps on resetting and turning off.
Make sure you check them one by one. hope this helps.
Sep 01, 2009 | Computers & Internet
HP530 shuts down within 15 seconds as it loads XP
Probabpy an XP problem, start XP in safe mode (press F8) as it is loading.
If it runs then it is probably a driver problem. Try restarting in the last good configuration. Keep posting until the problem is resolved.
Aug 17, 2009 | HP Computers & Internet
New emachine e720 trying to load XP pro - keeps blue screening - help
when your system shows blue screen while loading xp or after loading xp, it means your hard disk is faulty or your memory is not compatible with the systems.(hard disk 85% while memory is 15%)
Aug 12, 2009 | Microsoft Windows XP Professional With...
Explorer.exe Application error in Windows XP Professional SP2
This could be a memory problem or a problem with the OS (XP). If you can boot the original XP CD like your doing an install then it's not a memory problem more the likely. Can you boot your XP CD?
Nov 27, 2008 | Microsoft Windows XP Professional
make sure the machine detect the hard drive, and it is the right size.
WIndows XP will take some time to load and configure, if you have less than the minimum amount of memories, the system will stop.
check your memories. minimum 512MB, you really need minimum 1GB if not more. and make sure the CD is clean, no scratches.
Nov 05, 2008 | EliteGroup P4VMM2 Motherboard
Can't see all files loaded on 4 GB Cruz flash memory using WinExplorer(XP).
Check properties of the files . Transfer the different file and check it.
Feb 19, 2008 | SanDisk Memory Media
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
