My Epson cx4800 will print fine when I have the settings at text & image setting. but will not print photos at the photo or best photo setting. When I attempt to print using these settings it gives me a paper jam error continuously even though the paper is loading and ejecting fine
yes I did, no luck there! I actually did it twice
I have same problem. Only difference may be that mine is on a Mac.
yes we have its really annoying
I've have the same exact problem with my Epson R1800. Epson tech support tellls me it's a sensor and to try blowing compressed air into feed and exit area of the printer. I did that, but no go. ...I'm really dissapointed as the printer really hasn't been used that much, ...and it's too expensive to send back to Epson to reapair. An ink hog too with a set of cartridges running $140. Nozzle check, ...clean the heads, ...pump expensinve ink out to clear the nozzles, ...repeat, repeat, repeat. Goodbye to you Epson, you're pretty, but you're so fickle
Epson support tells me it's a sensor in the printer. I tried air blasting the feed and output, but it didn't help. This $500 printer goes into the trash as it will be too expensive to ship and repair. This machine has amazing prints when it worked, but the ink useage and nozzle clogs are unacceptable, ...constantly pumping their expensive ink through the nozzles to clean them. Phooey on you Epson
