I have downloaded a folder to the usb drive and now i have added more files ( pictures ) to the folder. how do i now download the new files o the usb drive without adding the pictures that are already downloaded? HELP thanks
  • hdarcangelo Nov 02, 2008
    i have no idea what you said but i'll keep trying. i appreciate your time and effort. thanks so much.
  • 550 Answers
Open a command window at the source folder
try a DOS command like this,
long line may wrap
replace the [usb*] with the spec for your system,, filespec can be anything, *.jpg *.raw that your camera requires
for %f in (*.*) do if not exist [usbdrive]:\[usbfolder]\%f copy %f [usbdrive]:\[usbfolder]
or you can make a batch file to do the same thing as this is likely to be a repeated task
@echo off
cls
echo Copying New Files
for %%f in (*.*) do if not exist [usbdrive]:\[usbfolder]\%%f copy %%f [usbdrive]:\[usbfolder]
echo New files Copied
Posted on Nov 02, 2008
  • AlmostBob
    AlmostBob Nov 02, 2008
    better batch file takes source & destination as arguments for multiple uses
    @echo off
    cls
    If not exist %1 goto error
    if not exist %2 goto error
    echo Copying New Files from %1 to %2
    cd %1
    for %%f in (*.*) do if not exist %1\%%f copy %%f %2
    goto done
    :error
    echo Copy batch file requires two parameters
    echo %0 [source] [destination]
    :done
    I had nothing else to do
  • AlmostBob
    Thought everyone has played with command prompts at some stage
    the command prompt is available from the right click menu in windows at most folders
    its a black boring window like the screen on a 1980s pc
    and you can use it as one
    if your USB pictures are in G:\PICTURES
    for %f in (*.*) do if not exist g:\pictures\%f copy %f g:\pictures
    will look at each file in the folder you start in one at a time, compare it with the folder you are aiming for, and only copy the file if it does not already exist.
How do i download photos onto a usb
Not sure what the problem is here, but if the laptop recognises the USB drive and it is formatted as a FAT device, you should see the device icon in "My computer". If you are downloading from your hard drive to the device, simply highlighting all the files by SHIFT and RIGHT mouseclick and dragging them onto the device will copy them.
If downloading from the internet, right mouse click and save target or picture as and point to the USB device as the place to save to
Jun 02, 2012 | HP Computers & Internet
How do I download all my stuff from my current computer to a new computer?
You can easily and safely use a USB pen drive with a large capacity to transfer all the files one by one , folder by folder with special markings to note the copy into the respective drives. You can also segregate the new drives to your need with personal files, general files and public files. Also picture and video downloads also can be listed and saved.Connect the USB to the old PC and transfer by copy or cut , then connect the usb after safe removal to the new PC and pasting to the new location.
Jan 06, 2012 | Computers & Internet
How do I password protect my eGo
Right click in your drive select new folder
Place all data files you want to password protect inside your new folder
Right click on your new folder select properties select the sharing tab
Scroll to network and sharing at the bottom
You have many options to password protect many files and folders Windows 7
In XP right click on your folder select properties then click the sharing tab tick the box do you want to make this folder private
A message might appear if you have a password do you want to create a password
Or you might download one or more of these all are free password protection programs
http://download.cnet.com/folder-lock/3000-2092_4-10063343.html
25 MB
http://download.cnet.com/truecrypt/3000-2092_4-10527243.html
http://download.cnet.com/my-lockbox/3000-2144_4-10789387.html
Hope this helps you
Nov 19, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Hi, i am trying to upload the picture on my camera (finepix S5700) unto my computer but it is not working, do i need to download the software first or what should i do.
Downloading the software shouldn't be necessary to download the pictures to your computer Hard Drive. Depending on your computer operating system be it PC or Mac it should handle your download as if it was an external hard drive or device. Saying this there are still a lot of "old" Windows program still in operation but if you have Windows XP home edition or newer then no problem. Mac's have a mind of their own and will look at the link as an external Hard Drive.
Maybe what the problem is the sequence in which you are attempting to download. Fist make sure the camera has sufficient power for the transfer of data, then turn it off connect the mini USB cable to the camera and the USB cable end to a computer USB port (nothing will happen at this point.) What I then do is make a folder in My Documents or (Finder) if you are a Mac, and title it with something that relates to the images which will be inside I generally use a month, day and date. At the end of the year (coming soon) I'll make a folder with the year and all the 2010 Months folders will be placed in there. Okay once you have a place to put the picture files turn on the camera in a few seconds the PC may say found a new device and then may put the external device icon on the desk top if not you need to go fetch it from system preferences. Open the file highlight the files and copy them click on the new folder you just made and past them in there. Check see if the picture files are there and then eject the external device/hard drive remember to turn off the device before shutting off the camera and disconnecting the USB cable. If it's a Mac once you turn your camera on the external Hard Drive Icon will appear on the desk top follow the same thing as with the PC. Then once you have "ejected the Hard Drive and the icon has closed shut the camera off and remove the USB cable. Wait you aren't done yet, now you need to format your memory card. Formatting the Memory card cleans the card of the old pictures and provides and clean medium to load new picture files to. Have fun Robert from Canada
Dec 29, 2010 | Fuji FinePix S5700 Digital Camera
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Dec 11, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
How do you download files from external drive to a hard drive?
Select the file you want to download to the computer hard disk, right click your selection and click on copy. Open the folder you want to download the file to and right click a space in the folder and select pest. The file will be downloaded to the specified folder.
Aug 08, 2010 | HP SimpleSave 1 TB USB 20 Hard Drive
Enet webcam Driver
http://imanabidi.googlepages.com/XP-...husbdriver.rar
Having downloaded the file you'd need to extract the files from inside the archive to a folder and then point windows at the folder with the extracted files in it.
You can download software from the link below to do the extraction:
http://www.win-rar.com/download.html
Once installed just double click the .RAR file and drag the files within out to a new folder. Follow the instructions above pointing windows to look for files in your new folder.
Nov 30, 2008 | Photography
I have recently purchased your 250GB Portable Hard Drive USB2.0/Firewire. The idea is to put all my thousands of photo albums, and computer pictures on one hard drive. each time I try to download a...
You have to specify the path to download the pictures.
Make a folder on your new disk then select that folder like default to download all your pics.
If you want only to pass all your old pic to a new disk, simply select the folder, >> then (right click) select COPY >> then Open the folder (already created) in your new hard drive and with a mouse cursor inside the folder (right click) and hit PASTE ---------All your files will start to copying
Nov 05, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
