Hi worcester 24ri wiring to y plan on boiler it says connect lp lr to pump and sw connect where over run pump
    Scholar:
  • 147 Answers
Dont know what your asking but the R is the hot wire to the thermostat, Y's are for cooling, W's are for your heat and the g is for fans. The Y's and W's turn on pilot relays, which control your AC and heat.
Posted on Nov 02, 2008
Operating worcester bosch 240 gas boiler
Control systems operate on a much lower voltage than the boiler. You should be able to put any kind of thermostat in for it. Just be sure of the wiring when doing it. If its a line voltage stat, I'll need more information to advise correctly.
Nov 15, 2013 | Heating & Cooling
Boiler Programmer user manual
contat worcester bosch they will be happy to send you a manual as you already have there product installed.
Dec 11, 2012 | Water Heaters
Worcester 24i boiler..how do i re-ignite the pilot light??
Overheat thermostat has tripped. If a modern Worcester need to press reset on control panel.
If older style Worcester - Pull front cover off the boiler (just above control panel flap pull the cover from both sides forward to unclip and then lift upwards to remove cover) and you will see a little brown reset button - press this back down.
However the over heat thermostat trips for a reason - was the system running on low pressure? It could be the pump is sticking a bit (dirt in the system) which can be sorted easily by adding an additive (DIY packs available at Home-base) . Or it could be the pump has completely gone. If this is the case it will trip again as soon as the boiler clicks back on.
Apr 27, 2011 | Heating & Cooling
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Worcester Bosch 35CDi II banging & wild pressure (CH only)
Hi try bleeding the pump it sounds like air in the pump , but worcester do have a free tech help line look for there wed page on line hope this helps
Feb 16, 2010 | Heating & Cooling
I need to replace a boiler pump on a Worcester Combi boiler and its a bosch pump Type UPS 15-60
Get connected to the internet and type;
http//www.gumfree.com/london/02/46316802/html;
or you can type Bosch pump Type UPS 15-60 and
you will find other option. God bless you.
Oct 20, 2009 | Plumbing
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
