Question about Kenmore 4292x Front Load Washer
Persistent F02 / SUD error. Tried all the tricks!
I have the HE3T, and I now can't get through a load. It stops running and begins flashing a F02 error. If I cancel and restart, it runs for a few minutes, shows a SUD error, and eventually stops with a F02 error again. I have cleaned out the filter, replaced the pump, and augered out the drain hose! What now?
  • 1 more comment
  • robert740 Nov 02, 2008
    This is happening with zero suds in the water.
    I've checked the hose from the pump to the bottom of the tank (as well as I can). I've also checked just inside the front load door, under the seal.
    What is next?
  • robert740 Nov 04, 2008
    Pulled off the hose between the tank and the filter. Found lots of debris (small items from wash) plugging the ball-valve just beneath the tank. It is working great now!
    Thanks!
  • Anonymous Mar 18, 2014
    The problem is not wash and drop the soup solution and some time see the code Sud F02.
    Genius:
  • 1,028 Answers
How about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
Posted on Nov 02, 2008
Received a SUD error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Whirlpool Fault Codes
Aug 26, 2014 | Washing Machines
Kenmore elite washer he3t- beeping F02
"F/02"
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 13, 2010 | Kenmore Washing Machines
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Getting an 02 F flash
F02 Long Drain
Potential Causes
Aug 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F2 code... stops part way through cycles.
Potential Causes
Jun 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My kenmore elite he3t showed an error code f02, i unpluged it and plugged in back in i tried to run a drain/ spin and the machine make a strange noise i suspect the motor filter is clogged and the moter is...
Potential Causes
***You stated that there was a noise when you started a manual drain. This may be a damaged drain impeller. in this case, replace the entire pump(drain).
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Have "sud" code and"f 02" code
I don't have a solution but I feel your pain.
I had an F02 error flashing so I got brave and took off the front panel and opened up the drain thing. What a mess! Water everywhere and OMG,the filter was caked with goop, a popsicle stick and a piece of metal.
I still get a Sud error so I am having the Sears guy out in the morning.
Oct 25, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 4292x Front Load Washer Logo
431 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
