Question about Dell Axim X5 Pocket PC
No wireless signal
I have a dell axim x51v that displays a BSSId wireless signal but the signal quality box shows no signal. Under settings it shows The device connects to "work" and the adapter that is highlighted is PPTP NDISWAN Miniport.
I purchased this second hand and both the seller and I do not have a lot of knowledge about how the wifi actually works. Any help in making the devise connect to the internet will be most helpful.
Steve
  • 488 Answers
Hi Steve!the easy way to connect to a wifi network is to switch on the wifi..as soon as it looks up a network it will propmt you..use the connect option and fill in the password if prompted..you should be connected..if this is the first time ur using this great device do read the manual at http://www.retrevo.com/support/Dell-X51v-PDAs-and-Handhelds-manual/id/281ag510/t/2/
you may need a free registration..also if you have not loaded any new software etc i reccomend you could do a hard reset and start the PDA like a new one!do remeber it will restore it to factory settings..
hope this helps..i could also help u out with any other issues u may have like software,tweaking etc.etc
best wishes!
Posted on Nov 07, 2008
Had dell axim51 for years...never was able to connect to wireless or any internet
The way to connect to the internet with you Axim is dependant on the wireless router setup.
for instace if the wireless is set up for WEP encryption there is a ( I think) about 8-10 hex chacters(0-9, A-F) that needs to be entered to connect. You will need to find these on your router.
Other system that are not protected should have no problems. connecting
hit the broken bars and the lower right corner, then hit the turn on button, then click on the site tab, this hould show you what networks are available. It will tell you if it is protected or is an open network.
This unit will only connect to 802.11 B wireless networks.
Aug 28, 2011 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC, i can connect to a wireless network, but i cant open any pages, such as google?? any help would be greatly apreciated!
Go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab', and make sure that 'My network card connects to' is set to 'The Internet'.
Hope it works for you!
Just my 2 cents... Carlos
Apr 14, 2010 | Dell Axim X51v Pocket PC
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
http://www.youtube.com/watch?v=9K2P_SNTuGo
Dell Axim x50v, x51v
http://www.youtube.com/watch?v=vEDvCklrNs0&feature=fvw
Dec 15, 2009 | Dell Axim X50 Pocket PC
How do I sync axim to outlook?
Try deleting the active sync partnership as mentioned in this post -
http://www.aximusers.com/forum/axim-x51-x51v/6651-synchronize-outlook-contact-problem.html
Jul 17, 2009 | Dell Axim X51v Pocket PC
Will not connect with pc
try to use the warranty of your dell 1525 contact dell wireless dep at 1-800-822-8965 ex 7246008 this is for dell corporate business dep // or if your under consumer dep. dial 1-800-624-9896 ex 69219
Apr 29, 2009 | Dell Axim X51v Pocket PC
Dell axim x51v pda
You need to do a hardreset on the pda to get the password removed.
Jul 24, 2008 | Dell GG057 for Axim X51, X51v
Will not stop scanning for networks...
One other issue I always encounter is that I have to disable both of the "power conservation" settings that would allow the Axim to shut off the WLAN radio when the battery goes low. Having them enabled (which happens by default) seems to keep my Axim from locking onto our WiFi. When I disable them, I get an immediate strong connection.
You can find these settings under the Dell WLAN ultility.
Oct 22, 2007 | Dell Axim X51v Pocket PC
Dell axim x51v and dell d810 conflict
Thats an easy one, simply uninstall your active sync reboot with axim of cradle then install newest version here : http://www.microsoft.com/windowsmobile/activesync/default.mspx
Aug 05, 2007 | Dell Axim X51v Pocket PC
Dell Axim X5 Pocket PC Logo
137 people viewed this question
Alun Cox
