Question about Mitsubishi WS-65511 65" Rear Projection Television
Mitsubishi will not turn on
After turning on my ws-65511 tv, it was on for only a moment then turned itself off & would not come back on. After unplugging & plugging it the green power light just flashes & the tv will still not come on. The tv is less than 3 years old & this is my first problem. Reset button does not help nor does unplugging set.
  • Anonymous Mar 13, 2008
    I recently had the same problem so I had repairman come out to the house and he said that it was the control module and wanted to charge me $600.00. Dont know what to do, any advise?
  • scarred Mar 13, 2008
    I recently came across the same problem so I had a repairman come out to the house and pull the chasis. He said it was the control module but the green light still flashed. He told me it would cost $600.00 to repair. Any advise or suggestions?
    Thanks
    Problem Solver:
  • 16 Answers
Im W/Techman. Your gonna hafto call in someone Qualified to check the set. Too many things can cause a Shutsown condition. There is a problem. The TV is made to shutdown for safty reasons. Good Luck Walter Grzybowski
Posted on Sep 22, 2006
    President:
  • 3,130 Answers
If the green light flashes, thats an indication that there is a problem in the sweep power supply or the horizontal drive circuit. Its not a problem a layman or unexperienced person should attempt to repair unless you know about electronic circuits and how they work.
Volume, device inpute issues
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mar 23, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Reset Mitsubishi WS-65511 VChip Password
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi WS-65511 Front Lock
Mitsubishi WS-65511 Manual Download
on May 03, 2010 | Televison & Video
Tip
Download Mitsubishi WS-65511 HDTV Manual
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
My mitsubishi ws 65511 turns itself off. sometimes right away sometimes after hours of watching tv
I believe you have an overheating problem. Unplug your set and go to the back, make shire all dust is free from the cooling holes. This should fix your problem. If not pull a little further from thevwall and put a personal fan blowing on the back. Hope this helps.
Sep 30, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
I hope that helps.
My Mitsu WS-65511 will not power on. When power is pressed on tv or on remove solid green light comes on for a moment as if television is going to come on and then it just shuts back off. I have tried...
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25.
Apr 05, 2009 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsubishi WS-65511 won't turn on.
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Feb 22, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65511 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65511 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65511 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
197 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
