Canon copier D760 paper jam
The paper was pulled in wrong direction. How do I release it or reset the sensor?
Try calling a authorized Canon Dealer to fix your problem
Posted on Nov 02, 2008
  • 62 Answers
Try turning the computer off. Otherwise the printer should reset the sensor itself. Otherwise there might be some paper left in the machine. Keep taking it apart (without removing screws) until you are sure all the paper is out. Re post if problem remains.
paul
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Canon imageRUNNER 2200
There is a paper jam below the sliding lid -
I suggest opening the right cover to remove paper jammed internally. There is a lengthy document at Canon support for your model: (you need to input your problem into the search box - ie. "ERROR LCD: Paper Jam" and click Search button).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9437
Dec 13, 2009 | Canon imageCLASS D760 All-In-One Laser...
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Oct 20, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I have d760 cannon copier. finally removed the
hi,
Check to see if there is paper in the fuser unit, it does consertina in it. I wood use a torch because these are difficult to see without a torch. Take the left covers off to see better.
Good luck
Oct 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Paper jams right before it exits copier
If the plate looks solid, then it's probably right where it should be. It sounds like a sort of ramp that feeds the paper into the fuser.
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Feb 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Paper jam on the ouy feed roolers
outfeed? u mean the fixing assembly?? where the paper gets warmed?? u need to unmount the panel, open the cartridge cover and unscrew. the slide panel and carefully unplugged the flat cable.
then you need to remove the platten glass. remove left small cover and then remove platten glass. remove the black cover besides the scanner. now remove the left covers, all of them, and unplug the fixing assembly. they are at least two connectors that go right to the power supply board. now you need to unscrew the fixing assembly, see the top of the recently uncover top, you must see two holes, thru them you should see screws, two on one side and one on the other, unscrew them, and then you will finallly release the fixing assembly. now that you got it out remove the plastic cover if it's there and then remove the two screws that has one on each side, now rmeove the metallic cover, you may need to unlock a little metal locks on the sides, push or pull depending situation and then finally free the unit from its cover. at this point you must be really able to remove all the jammed paper. clean up with pressurized air if possible. now that is paper free you need to mount everything back as original. good luck!!
Jan 30, 2009 | Canon imageCLASS D760 All-In-One Laser...
Won't copy document through feeder.
When you say it won't copy, do you mean that the paper won't move in the feeder or that no copies come out? Do you get any error messages? Try using alcohol on a swab or lint free cloth and clean the feed rollers in the feeder. They sometimes get paper dust on them and they can't pick up the paper. Also make sure that any paper sensors that detect when paper is in the feeder are intact. Occasionally they get stuck or broken. Hope this works.
Sep 22, 2008 | Canon imageCLASS D760 All-In-One Laser...
Cleaning a Canon d760
I am not sure of that ,the best way to clean it is to do it manually by having the machine being serviced by an expert .
Dec 12, 2007 | Canon imageCLASS D760 All-In-One Laser...
42 people viewed this question
k24674
jasbo
jasbo
