Question about RCA HD52W59 HDTV Projection Television
No Power We where watching tv my young daughter flipped the switch for the power off and on a number of times. Now the tv will not turn on at all. Nothing working.
    Genius:
  • 1,030 Answers
Does the front green led light flash?
unplug the set for 30 min then replug try to turn on. if the light does not flash then i might be a main fuse. Point... main fuse falure ussally means more than just fuse. if the light flashes then you have a shutdown condition. This set processor shuts it down for 1 or 25 different reasons as technicians we have a computer that reads errors much like a cars error codes.
Posted on Nov 03, 2008
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Tripping the breaker
Could be a number of things but I would first suggest that you check the plug (from the TV) for wires touching inside ie: neutral and/or earth touching the phase terminal and/or damaged cable.
Hope this helped
Jan 28, 2014 | LG 42LC2D 42 in. LCD HDTV
Sony bravia KLV-32S550A when i turn on tv green light(POWER LED) flashes red for 60 seconds on and off after total power shutdown. pl tell me what a problem
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 02, 2013 | Sony KLV-32S550A 32 inch Multi-System LCD...
I have a T105R-41. In order to vacuum the pool I have to flip the switch to on along with a power switch. How do I turn off the filter and keep the timer set? Thanks.
T105 is 120volt timer with NO NC terminals:
http://waterheatertimer.org/pdf/t105.pdf
The model number of timer shows inside the door panel. However any Intermatic and some GE timing mechanisms can fit into the same box, so wiring has to be checked with diagram shown in manual to be be sure.
Problem is not clear.
You are operating two different things: the filter pump and the pool vacuum?
You want the filter to operate via the timer.
And you want the pool vacuum to turn on whenever you flip a power switch, except the power switch is wired into the timer ... which means you have to flip the timer manual override lever and flip the power switch to operate the vacuum.
To work around this problem, rewire switch wires so they connect to terminals 3 and A.
Black wire to terminal 3 and white wire to terminal A.
For more information, add a comment.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Jul 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a Panasonic TCP50G20. The TV was on for about 6 hours today. My daughter turned it off. She tried to turn it back on about 1 minute later, it wouldn't come on and now the power light just...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 12, 2017 | Panasonic Televison & Video
Toshiba model 61h71 red light comes on /no picture or sound
We had the same problem, open the panel on the back of the tv, the board on the left, not the one with the convergence chips. Inside the tv u will see a piece of paper with the fuse info. The board on the left unscrew it and flip it away from you, the fuses to test are at the bottom, on the circuit board it will say 125volt 5 amp, and the number starts with an f. they are small and rectangular and black. Check all but the 3 at the bottom are usually the culprits Hope this helps u
Jan 14, 2009 | Toshiba 61H71 61" Rear Projection...
No Power
Check the fuses and capacitors on the power supply board. A power surge during the flickering may have taken one out.
Nov 02, 2008 | RCA HD52W59 HDTV Projection Television
On and off
That hapened to me once and the solution that worked for me was unpluging the TV for about 5 minutes and pluging it back in, you may just need a new remote though.
Jul 28, 2008 | Philips 55PP9352 55" Projection Television
Sony 27" XBR failure
I will suggest dont ise it until someone who is qualified comes over to give you an estimate,I belive you have a lot of loose conections in the horizontal driver and output circuits,power supply and crt board.Should not be expensive to repair right now. Good luck.
Sep 18, 2006 | Sony KV-27V42 27" TV
RCA HD52W59 HDTV Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
