Question about Microsoft Xbox Console
Xbox contoller problem
When my controll is inserted in slot #1 it says it is not inserted and when i use my other controll it still doesn't work. How do i fix that?
  • rchughatta Nov 02, 2008
    Dan,
    I have already tried that
Hi Rchughatta,
I sometimes have the same problem. Just blow away the dust from the ports and it usually works again.
Dan
Posted on Nov 02, 2008
I can not getdangeroushunts20 controller to connect
Try pressing the sync button on the top of your controller and the one on your xbox (under memory card slots) at the same time. If this doesn't work, try changing the batteries.
May 06, 2011 | Microsoft Xbox 360 Elite Console
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
Feb 24, 2011 | Microsoft Xbox 360 Controller
Controler wont conect with my xbox, light on xbox panel and contoler will only cyrcle but player one or two will not turn on. Its syply not conecting controler with xbox
1. To sync a controller with the Xbox console you must first push the sync button on the controller first!
2. Then you must push the button on the console second.
3. If problems still persist, then you might want to check the batteries on the remote.
Feb 02, 2011 | Microsoft Xbox 360 Console
I have a old xbox system and my wireless controllers by pelican brand pl-2050 one will not link up to the xbox what to do!!
Check to verify that your batteries are installed correctly.
- Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off.
2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
6. Turn on your Xbox and insert a game.
Aug 06, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
Need to sincrinize contoller with console
press the sync button on the xbox and then the controller
Jul 01, 2009 | Microsoft Wireless Controller for Xbox 360...
My 4Gamers controller for PS2 doesn't work.
well get a new 1 den we cant fix dat can we dikhed
Apr 09, 2009 | 4gamers Playfree Vibrating Wireless...
Xbox parental control
Try doing this. It should work:
1. From the XBOX dashboard screen, go to settings and then parental control.
2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
3. Enter in a new password, or disable parental control entirely.
Sep 10, 2008 | Microsoft Xbox Console
XBOX 360 Controller
well try to call xbox technical support amd they will help you out. the number is 1-800-4myxbox. tell them your problem and they will most likely give you a box in the mail for you to send it in and after a few weeks later you should get a new one in the mail
Mar 13, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
