Question about InFocus LP725 and LP735 Replacement Projector Lamp - SP-LAMP-LP7E Projector Lamp
Infocus LP725 Replacement Bulb
I purchased a LP725 prjector with a broken lamp. SInce then I purchased a replacement lamp. The new lamp has only done approximately 300 hours (knowledge from the previous owner). A phusical and continuity check of the lamp reveals that the light is good to work. I installed the replacement lamp into the projector and turned it on. The fan runs up however the globe does not illuminate. Checking the manual that came with the projector, (there is not much information supplied in the manual, more like a glossy sheet about how to connect other peripherals to the projector) does not give me any advice on what is required for a replacement globe. What steps (please in specific details - like button resets, or globe hours etc etc reset or any other information that can help me in getting my projector work. Does anyone have a service manual for this projector as well?
KInd regards Joe
  • 2,237 Answers
If you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Posted on Aug 03, 2009
Quantum cxl. Why doesn't replacement lamp work?
Or it could be the incorrect bulb for the machine or if purchased from a secondary market, ie China, etc. I've purchased a replacement bulb from eBay and even though it was guaranteed to work in the machine, there is a lip on the bulb that prevents it from being inserted completely into the machine. Might be best to purchase an authentic replacement bulb from a dealer.
Feb 22, 2016 | Singer Sewing Machines
No power
if there anre no leds lit on the top, the power supply needs to be replaced.
Jan 19, 2010 | ASK Proxima C160 Multimedia Projector
Just got a new bulb assembly in today brand-new inserted it made sure everything was seated properly after about 45 minutes a large black spot appeared never had this trouble before put the old assembly...
dcamp77262, you mention that the new lamp worked for 45 minutes and then the dark spot appeared, was this the same with the previous lamp and was the previous lamp the original that came with the projection unit? If you're using a replacement lamp(not original equipp) won't be the first time that they send a lamp that does not match the ome lamp, it also could be (very possible) that you're going to need light engine replacement or repaired.
Jul 30, 2009 | InFocus Televison & Video
Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
May 23, 2009 | InFocus X1 Multimedia Projector
Infocus Lp240 Projector Will not power on NEW BULB. Red light Blinks on and off.
The owner's manual should have a troubleshooting chart that will indicate what the blinking lights mean. If the new bulb did not clear it, the problem may be the ballast (part that starts the bulb). Also, when you replaced the lamp, you should also reset the lamp timer. Some units will continue to indicate a lamp needing replacement until the counter is reset. The procedure for that should also be in the manual.
Keep us posted.
Dan
Dec 18, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Replacing bulb
hold the volume up/down in ,switch unit on while holding these in for 30 secs, if that fails, flash unit with new software.
Dec 01, 2007 | InFocus In Focus SP-LAMP-021 Replacement...
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
Infocus LP725 projector
May 25, 2007 | InFocus LP725 and LP735 Replacement...
350 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
