Question about Canon PIXMA MP210 Photo All-In-One Printer
Scanning I am trying to scan some pictures but the printer will not scan. The printer will displace E2. Please help me.
    Master:
    Sergeant:
  • 461 Answers
Not sure what is your OS using for this printing but you must make sure your driver use suit the OS otheriwise it may not work. To get details about driver you may find below link useful..
http://etech.maiila.com/canon-pixma-mp210-photo-all-in-one-printer-driver-manual-and-software
Good Luck
Posted on Nov 02, 2008
How to scan a document in HP F 4288 deskjet
Open printer suite and open scan option from it.
or
Open Microsoft Word > Insert > Pictures > From Scaner > Scan page will come out > Preview > Scan > Picture inserted in Word page > Set Picture In front of text > OK > right click at picture > save as picture file > choose save as JPEG file > Save.
Now you can use it as picture files.
Hope this help and if helpful RATE please !
Jan 20, 2011 | HP DeskJet F4280 All In One Printer InkJet
Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanning Problem.
If there is a seperate plug for your scanner, make sure it is not unplug from the printer.
Dec 29, 2009 | HP PSC 1410v All-in-One Printer
Turn on copier and get noise then E2 10. Can You
E2 Scan problem
Check motion scanning device. Check the position a sensor on carriage, they controlled, and are fixed by bolt. Can fixatives on lid have from below lost its fastening
Oct 10, 2009 | Office Equipment & Supplies
How can you scan on printer canon mp 180?
go to 'control panel' click 'printers and hardwares" . then yu will find "scanners and cameras" potion click it and follow the procedure of scaning.please do load the document to be scaned first.
Jul 06, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Scanner on Sharp AR-M350u is showing NG800000 and is not sending scanned items.
This mistake NG800000 offset scanning device.
1 Try reinstall a driver on local on cord USB
2 Remove glass of the scanner and check displacement scanning device, it must softly move. Smazhte nodes mask, продуйте the sensors, check join a wire. Do Not use the long cord USB gets lost the signal, appear the hindrances.
Write, help. Good luck
Jun 22, 2009 | Sharp AR-M350U Copier
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
Getting to just scan pic into the pc
First of all ensure that you have all of the drivers for both the printer & scanner installed on your PC. You will also need the Epson Scan utility installing. These should all be on the disks that came with the printer or are available to download from Epson:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&prodoid=63075469&infoType=Downloads&platform=All
To scan a picture into your PC, just click on the Epson scan icon on your desktop (or from within your Start menu's). Place the picture to be scanned face down under the scanner lid and press the scan button. Don't forget to save your picture before exiting the scan utility. Please take a moment to rate this solution. Thanks.
Mar 05, 2009 | Epson Stylus NX400 InkJet Printer
Scanning
Scanning Photos With the Control Panel Scan menu, you can scan photos to a file, application, or memory card.
Scan to File 1 Place a photo or photos face down on the scanner glass.
2 Press Scan to display the Scan menu.
3 Press �� or �� to select Photo.
4 Press �� until Scan To is selected.
5 Press �� or �� to select File.
6 Press Start.
The document is scanned and saved based on the Kodak AiO Home Center scan picture settings.
You can change the folder where you want these saved. Just go to tools in your printer window.
Hope this helps- Happy scanning!
Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Only scans and copies black blank
please check if the exposure lamp. or the ligth that runs when scanning works if it does not turn on change that parts
Jun 16, 2008 | HP PSC 1510 All-In-One InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
110 people viewed this question
old marine
old marine
