Question about JVC RX-8SD Receiver
JVC KD-S24 wiring problem
I have wired the radio by the wiring chart. The pre set lights come on the volume light comes on but the radio station readout doeant work also will not take a CD and no sound from the speakers.Really the only thing working are the pre set lights and volume light.any ideas would be helpful.
snakehead
  • 1074 Answers
SOURCE: JVC RX6040 OVERLOAD TROUBLE
clean your volume control if that does not help take it to a tech for repairs.
Posted on Mar 30, 2007
  • 88 Answers
SOURCE: Sterio problem
User manual here:
JVC America - User Manuals
Hope this helps,
erch.
Posted on Mar 15, 2008
  • 88 Answers
SOURCE: How do a change the
User manual here:
Hope this helps,
erch.
SOURCE: JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Posted on Oct 06, 2008
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
I have a jvc kd-r45 it will not recall any pre set radio stations after it is switched off and demo mode kicks in every time i start it up. Tried reset any ideas?
I don't think you have the memory keep alive wire attached to a constant 12V+ source. This is why it is not keeping set stations and reverting back to demo more every time it is switched on. Usually the memory keep alive wire is yellow.
Jan 18, 2012 | JVC Car Audio & Video
Kd-sx940 manual/instructions for wiring?My original radio was stolen from my 1998 Ford Ranger and they cut the wires,I bought this one but it has the wiring harness to a Subaru,I don't care if I have...
installation manual:
http://books.jvc.com/Download/18989249/FSNU3070-T632.pdf
And, for what's it's worth, the instruction manual:
http://resources.jvc.com/Resources/00/00/99/FSUN3070-632.pdf
May 22, 2011 | JVC KD-SX940 CD Player
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Jul 13, 2010 | JVC KD-SX650 CD Player
I hooked up my JVC KD-R200 to a 1991 Toyota Tercel and I can't get the face of the stereo to turn on. No sound, no radio stations, just the lights around and on the buttons come on. I have another stereo...
try reversing your red (accessory) and yellow (constant) wire... also check the fuse on the back of the radio. and it wouldn't hurt to clean the connector between the faceplate and the radio either corrosion can cause this....
May 01, 2010 | JVC KD-R200 Car CD/ MP3 Player
I cant get my raido to save my time or my radio
make sure that you have wired it to the manufacturers spesification, ie, that you have one wire, ususlly the yellow , going to a permanent, not switched power sourse
Oct 22, 2009 | JVC KD-S580 CD Player
My car stereo a jvc kd-s6060 losses pre-set stations when its been turned off.
Your wires are probably backwards. the yellow one is for memory and it gets wired to direct battery voltage to hold the memory. The red wire is for power when key is turned on.
Oct 06, 2009 | JVC KD-S6060 CD Player
Need manual , it is a jvc KD- S24
is it KD-S24J....? I put the J in there. If that's right go here...(copy and paste)
http://books.jvcservice.com/Download/313099664/GET0516-001A.pdf
Sep 24, 2009 | Car Audio & Video
198 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
