Question about RCA HD52W59 HDTV Projection Television
No Power My TV was on and my young daughter flipped the light switch for the power on and off a bunch of times now the tv will not turn on at all, no power no lights nothing.... HELP....
Check the fuses and capacitors on the power supply board. A power surge during the flickering may have taken one out.
Posted on Nov 09, 2008
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
May 18, 2009 | Jensen Televison & Video
The green light comes on then turns to yellow.
if you look at the capacitors on the boards you will find several of them that are domed or blown, these are the most likely cause of the problem. you can find replacements for any capacitor online at electronics supply stores, like radio shack but don't try them they don't supply enough different types. you can also find examples of blown capacitors by doing a search for "blown capacitor image" on any web search. unsoldering these bad caps and replacing them with identical values like 220uf (microfarradys) and say 25 v(volts). these caps have a + side and a - side the caps are marked and so is the board. hope this helps.
Mar 20, 2009 | Proview PL926WBi 19" LCD Monitor
Toshiba model 61h71 red light comes on /no picture or sound
We had the same problem, open the panel on the back of the tv, the board on the left, not the one with the convergence chips. Inside the tv u will see a piece of paper with the fuse info. The board on the left unscrew it and flip it away from you, the fuses to test are at the bottom, on the circuit board it will say 125volt 5 amp, and the number starts with an f. they are small and rectangular and black. Check all but the 3 at the bottom are usually the culprits Hope this helps u
Jan 14, 2009 | Toshiba 61H71 61" Rear Projection...
Green power light blinks about 20 times then turns off tv
Your TV is telling you to contact a repair shop because it has a very serious power problem. Check your power outlet with a cheap plug in tester you can get from any of the chain hardware stores to see if you have a problem with electrical outlets that you are plugging into.
Dec 01, 2008 | Mitsubishi WS-55859 55" Rear Projection...
No Power
does the front green led light flash?
unplug the set for 30 min then replug try to turn on. if the light does not flash then i might be a main fuse. Point... main fuse falure ussally means more than just fuse. if the light flashes then you have a shutdown condition. This set processor shuts it down for 1 or 25 different reasons as technicians we have a computer that reads errors much like a cars error codes.
Nov 02, 2008 | RCA HD52W59 HDTV Projection Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Dell w3000 has green power on no video just audio only
Had same problem as described by others, green light, audio, but no picture. Decided to look inside. Layed the TV face down on three textbooks (1 at top & 1 at left & Right) so that back (9 large screws & 2 small screws) could be removed along with stand. From the power supply (board that 110v AC plugs into) there is a cable connected to a circuit board on the left (again looking from the back of the TV) covered by metal shielding. Unplug this cable clean the male contacts with a miniture wire brush (bought mine at Home Depot) & plug the cable back into the socket. With rubber gloves (just to be safe) plug the AC cord into the back of the TV & wall and turn on your TV. The bulbs should activate in 7 - 8 seconds. Reassemble the back of the TV & install the stand. Enjoy your TV Doug
Sep 08, 2007 | Dell W3000 30 in. HD-Ready LCD Television
RCA HD52W59 HDTV Projection Television Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
