First tilt this machine back and examine the belt assembly and then start the timer at spin and note the action. If you see one pulley **** and try to turn check to see if it is the motor. Then try it with the belt off. If the motor spins free let it for 2 minutes to ensure it is not failing. The worse case is the gearcase has failed and will need professional help.
Admiral HD 2 speed --- 2 of the 3 screws that hold the tub to the main drive assembly have come out,...
(More)
Admiral HD 2 speed --- 2 of the 3 screws that hold the tub to the main drive assembly have come out, causing the unit to leak. I have dis-assemled the entire unit but cannot get the main drive off to replace the screws. How does the main drive come off?
