Question about Dryers
Wiring problems hunter model 23272
I have a hunter fan w/remote control model 23272 the Grand Lodge and I don't have the book to wire the remote to the fan to the house wires?
Coldcut
  • 1554 Answers
SOURCE: wiring a ceiling fan with a remote sensor
since you have a remote, you don't need that extra wiring for the light/fan. just wire nut it off.
the switch at wall has 2 switches but only one will work now.
Posted on Mar 31, 2008
  • 5 Answers
SOURCE: hunter fan/light control wiring
solution depends on how many wires are in the ceiling box. was there a ceiling fan in place before? were the light and fan controlled by seperate switches or was there only one switch? if two switches, then there should be two seperate hot wires in the ceiling box. if only one switch, then only one hot wire in box. if only one, then your black and red from the fan will wire together to the single hot. green goes to the bare copper wire, if not one, then not needed
Posted on Aug 14, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
jse2005
  • 103 Answers
SOURCE: Hunter Lodge Fan will not remain on HI... will go down to LOW
have the wiring checked for proper and good connections....other than that, the control module in the fan ( the receiver) is defective.
Posted on Jul 25, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Why does our remote receiver, model #85482-01, keep resetting itself?
That's a tough one; this could be coming from a malfunctioning transmitting or receiving unit, or outside interference.
Did the handheld remote get dropped just before this problem started? Or maybe have something spilled on it? One way of ruling out spurious emissions coming from the transmitter is, once the fan is operating, remove the batteries from the remote. If it still changes modes it would NOT be the remote. Proceed to the next step.
Have you had electrical storms or power outages around the time that the problem started? If so the receiver may have taken an electrical hit. Inspect it carefully for signs of arcing or smoke, fried wires. Also sniff it, if it has a funny (burnt) smell that's where the problem is. Of course the receiver could malfunction without and power surges and that would be harder to isolate.
Lastly, outside interference; This is very hard to determine without any test equipment. If someone living near you installed a garage door opener, Set-up an amateur radio station, or started using some piece of new electronics you might be interfered with you. I have seen electric lawnmowers do some strange things (interference). I was also was once on a call where the guy next door actually went out and bought a programmable remote control to mess with my clients TV, some kind of neighborhood squabble.
Hope this helps, best of luck to you.
May 17, 2014 | Hunter Dryers
Hunter 85112-02 Ceiling Fan Receiver
I believe the lutron will connect at the pull switch. That model # isnt workings for me though. I am finding 85112-02 but not 04. You can try googling 85112-02 remote wiring and there are many results. The hunter remote module may stay in place and the lutron will connect via the pull string wires. maybe. If you can confirm the model and maybe the lutron model I can look more.
Jan 10, 2018 | HunterFanCompany Cars & Trucks
Problem with hunter ceiling fan 23272
The problem is with the remote receiver attached to the fan body. It is a small device that acts as a remote switch and this is cradled in a pocket inside the ceiling fan itself. If you are handy, you can replace this device yourself. I believe you need to purchase a new kit from Lowes that comes with a matched transmitter and receiver for fan control. Go to Lowes Lighting section for this product.
Jan 12, 2018 | Hunter Dryers
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
Hunter 'lodge' ceiling fan w/light: all switches 'on' and light blinks???? what do I do to correct problem?
if problems with the light blinking, remove watt governor inside fan, for lights. and wire the lghts directly. this should fix problem. the watt governor is a small black box to reduce wattage on the lghts. just remove it and wire lights directly. have a good one !!
Dec 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Jul 25, 2009 | Aloha Housewares (93645) Ceiling Fan
Hunter fan model 23272 with remote control
Sometimes fan remotes can get interference from several rf sources (maybe another fan remote or garage door opener, etc). You can try to change the DIP switches in the remote and the reciever to a different frequency. The switches in the remote are probably in the battery compartment, and on the reciever which is located in the ceiling canopy (most likely), or in the round box where the light kit attaches.
Jan 07, 2009 | Electrical Supplies
Grande Lodge Fan
I have an existing ceiling fan with an add on remote control. Does anyone have a wireing digram or can tell me how to wire it up. The switch on the wall kills all the power coming to the fan. I have the color wires wired together(pink to pink , etc.) It is a hunter add on divise. Model # CP911OR
Aug 06, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
318 people viewed this question
Top Dryers Experts
