Question about Campbell Hausfeld Garden
Campbell hausfield power washer Model #pw175500le
The engine starts but will not keep running.
  • 211 Answers
Hi
First priming hte engine(put some gas in the plug hole)and start the engine for few times until the engine runs constantly.If not there is a fuel delivery problem.Check the air and fuel filters,the fuel line,the muffler and screen inside.Disassembly the carb,check and very carefully clean it with compresed air.
best regards savumihai71
Posted on Feb 14, 2009
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
My campbell hausfield wl660001aj will not come on and I changed the fuse also. 5 gallon vertical
Water is condensed from the compressed air it makes and this can settlel in the switch diaphragm, in cold weather is can freeze and prevent the switch from working.....
Feb 02, 2010 | Campbell Hausfeld Air Tools & Compressors
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Campbell Hausfield wire welder feeds after trigger release!
has it done this before some wire feed welders the cheaper ones have hot switches mean that push wire all the time stuped i know but if it is not a hot switch than it is making contact some how and it could be inside the wip check it as best you can or take the wip in to where you got it from
Nov 10, 2009 | Cars & Trucks
Wont come on when switch is pushed to on
looked up Campbell Hausfield service on internet. found dealer within 1 mile of home.
Sep 11, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Sep 04, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
Wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Garden Logo
436 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
