Question about JVC THC5 Home Theater System with 5-Disc DVD Changer System
Disc tray and playback problems
My JCV TH-C5 system is not ejecting the individual disc trays, and it will not play the DVDs and CDs that are in there either. The only response I get when I press a command is a mild buzzing noise, as if the system is trying to respond to the command, but cannot proceed, and then the buzzing noise stops (which lasts for about 6-7 seconds). I have already locked and unlocked the disc tray ejection, as a form of resetting, but witnessed no change.
  • Anonymous Nov 29, 2007
    Will not eject the dvds and is showing that it is unlocked
Unlock codes for xv-thc5
Posted on Feb 14, 2008
This problem is caused by the "worned out" rubber band that enable the mutiple trays to rotate.Hence, the disc is not able to be detected and played by the system. Remove the system cover, take a look inside at the rotational axis part and replace the "rubber band" that loses it elasticity.
Posted on Aug 21, 2007
    President:
  • 3,130 Answers
Unplug the unit for 12 to 24 hours. if that doesnt work, take apart the unit and manually clean the lens on the laser assy with a cotton swab and a little alcohol. Dry it off with the dry end of the swab and see if that helps. if it does not help, your going to need to take the unit in to be looked at.
Posted on Sep 22, 2006
SOURCE:
Does not play when disc entered nor when play is selected. (XD-E500KB)
Hello
Push in the plug connected to the "Video Out" jack on the rear of the Dvd to ensure it is connected firmly. Check the connection at the back of the TV as well.
Press the "Source" or "Input" button on the TV remote to verify the television's input is set to the DVD connection.
Press the "open/close" button on the front of the DVD to open the disc tray. Insert and test different DVDs to determine if the problem is with a specific disc, or if the player will not operate.
Eject the DVD tray and insert the DVD laser lens cleaner. Close the tray and wait a few seconds for the cleaning disc to load. Press "Play" on the front control panel to spin the disc through the cleaning cycle.
Remove the cleaning disc, insert a DVD and test playback operation. If the machine still will not play discs, the main receiver unit may require internal repairs best left to an experienced technician.
THANK YOU FOR VISITING FIXYA
Feb 02, 2011 | Toshiba Televison & Video
It seems that the dvd player is jammed. Cant get dvds out or in. Wont play. Is there some kind of reset or something I can do to fix it. Thanks
its very common for 1 of those 5 trays to get stuck in the unit usually with a disc as well --you will have to manually go in while its unplugged elevate the tray by spinning 1 of the 2 large gears near the front of the mech and reseat the tray
Aug 31, 2010 | JVC TH-C5 System
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
My xbox plays cds/movies but not games. what do i do?
this is a problem the microsoft has been working on ... remove any disc from the tray> unplug it from all power the plug it back in> open the disc tray .. leave it open for a little while like 10-15 seconds .. then put the game in and it should work .. if it does not however you have one of the defected disc trays and you'll need to get it repaired by microsoft .. i know its not what you want to hear but hey at least they will fix it free of charge =]
May 28, 2009 | Microsoft Xbox 360 Console
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
Wont play dvds, only cds, music and photos when dvd placed in tray, goes through reading process, then ejects tray with an on screen message, unknown disc! With all discs not a certain few. when a blank...
DVD & CD use different wavelengths for the read head. I suspect that the blue laser is out of alignment or otherwise in need of repair.
PhotoCD is a format.
Jul 20, 2008 | LG Televison & Video
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
226 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
