Question about Envision EN-9250 19" Flat Panel LCD Monitor
My screen is not clear there lines, shodows and it looks like water
    Problem Solver:
  • 18 Answers
Some of your monitor capacitor might be bad, so check on that, it might be water damage also.
Posted on Aug 14, 2009
Kenmore washer won't fill with cold water
Check your cold water intake line to make sure it's not kinked and that the house valves are open...You'd be surprised how often something falls behind the machine and either kinks the line or yanks the valve closed.
If they are clear, then remove the hose from the faucet, and take a look to see if the screen that goes across the inside of the hose is clear. The screens can get clogged with the sandy mineral debris they are intended to keep out of the pump, but it just takes a rinse to clear them usually. If it's more stubborn debris, you may need an old toothbrush or similar to clear it, or, if it's badly blocked enough, you may need to replace the screen altogether. Yank the old one out with needlenose pliers and put the replacement in before reattaching it to the water supply.
If none of that helps, you may need to start looking at the internals of the machine itself, starting with solenoid valves and temperature selector switch.
Sep 06, 2014 | Washing Machines
Pfister f0264cbs repair schematic
I'd look at the water shut off valve that the faucet is connected to coming out of the wall. In time the rubber washer that shuts off the water flow will deteriorate enough to cause part of it to travel up line and partially block the faucet.
Mar 06, 2014 | Price Pfister Plumbing
Only fills with cold water...when switch is switched to hot or warm it doesnt fill with water....or it barely trickles out with hot water....and if it needs parts can I find a parts book...I've lost the...
There is a small screen filter inside the connection for the hot and cold water valves. This screen helps prevent minerals and small contaminants get inside the valve and prevent it from seating and closing properly. If water is just trickling out, this screen could be clogged. You can remove the screen with a small pick or screwdriver and either try to clean it out or replace it.
Jan 29, 2011 | Washing Machines
My HP 5880n TV has started showing purple lines everywhere. Particularly in images that should be shiny. Images of water are the worse and look almost all purple as each shiny part is surrounded by a thin...
I got some water between the 2 screens at the bottom of my HP 5880n. I took the screen out and separated the 2 screens at the bottom and wiped and let dry. I put it back together after it dried and put back in tv, now when it1s on it has a foot and a half circle that is clear as a bell and the rest looks blurred. is there a fix for it or do i have to replace. Where can I find a replacement, I looked on line and can not find any. Thx
Aug 18, 2010 | HP Md5880n 58 in. HDTV
My water in the kitchen has a problem. When I turn the hot water on, the water pressure is very low and a load noise starts after a minute or less and the water starts to slow down. The dishwasher runs ok...
change the water inlet hose screens as they are plugged,also put the hoses on a hot water line and run hor water thru them and see what comes out of them in the sink,then replace the washer inlet hose screen
Mar 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Ice maker not working
The activity with the water supply could have loosened some sediment in the line stopping up the little wire screen filter going into the water inlet valve. I would disconnect it and inspect the screen and flush the water line out before re connecting. Assuming you have water at the water dispenser Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 30, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Cold water dribbles into the washer. The cold water line is clear with LOTS of pressure. Is there a filter in the washer that needs to be cleared. If so, how?
sometimes on the hose there is a filter, "screen "check the hose at both ends to see.and somtimes the unit at the hose connection has screens on the unit where the hose connects to the unit,look to see if the screens are clogged,if so just remove them this will help your water problem.
Aug 04, 2009 | Kenmore Washing Machines
Black vertical bands in screen. Started as faint shodows now dark
Replace the ribbin cables that connects to the lcd panel. don't have part #
Jun 10, 2009 | Sylvania 6626LG 26 in. LCD Television
Help Please!!
Convergence problem . IC's are bad and should be replaced. If you can unsolder and solder you might be able to do it . Or a repair shop should be able for about $250.00 - $300.00 . call around for best price . Good luck
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Please Help... Strange blue reflection across screen (See image)
Convergence ICs are bad and posibably th eresistors that power them. Its an easy fix if you can solder
Envision EN-9250 19" Flat Panel LCD Monitor Logo
64 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
