Question about ASUS P4SP-MX Motherboard
Failed MB ..??
I am getting primary drive failure on this p4sp asus motherboard and I have tried 4 (PATA) drives with no change. It goes through the post test but fails with primary drive failure. I have tried everything including reconfiguring rom bios. I need to get a known good MB to troubleshoot this problem which I can do but I need to find out what other ASUS or other MBs are compatible with PATA only HD controller chipset. If I can go with another MB even non ASUS I will. I have all these good PATA drives from 40 to 80 gig and want to use them.If anyone out there knows any sites that have compatibility lists or cross reference lists I can do my own homework on this. Thanks
  • 3 more comments
  • jrgossett Nov 02, 2008
    The PC was originally Windows 2000 Pro on the Seagate Caviar 40G it came with. I would like to use this OS because the HD also had a full Microsoft Office suite and other features I wanted to use. I planned to use this PC wilth multiple hard drives using one of the Linux distros on one SATA drive and XP on two or more of the other drives for storage and etc.
  • jrgossett Nov 03, 2008
    terrier - Yes sir - will do.Thanks for expert comments!!
  • jrgossett Nov 06, 2008
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    terrier: There are two IDE switches in this Award v6.0 bios
    - onboard pci enable and IDE bus master support both of which were enabled. I
    was sure this idea would work because I had seen these switches earlier but apparently
    the three Seagate drives I have are bad and not coming up at all. The one Maxtor I
    have however did come up in the GRUB prompt (wouldn’t you know it!) which
    is why I want to use separate drives for each OS anyway. I have lost a lot of
    data using grub in the past for which there is now a solution with the new
    Super Grub disk (links are all over the web) which works really well by the way
    and is also useful for other HD FAT and other problems. This shows me the HD
    controller function on the MB is OK and that the other drives are bad but that
    is OK and I am thrilled that I can get this system going anyway I can. I can always get other ATA drives for cheap if I
    need more storage. Thanks for great help and comments.
    Sorry for garbage data on the header of this reply. I pasted this in from a Word file and for some reason this format picks up the header and etc.
    terrier- Also I didn't explain that I set the HD hardware straps to "cable select" to make this Maxtor work. I noticed one time that the Maxtor came up as a slave in the bios so as soon as I set cable select it came up in the grub prompt. Your suggestion had me trying all the bios switches again on this problem so this led me to "a" solution and I am happy that the MB HD controller is at least working and this tells me a lot. Thanks again.
  • 94 Answers
What os are you using?
Posted on Nov 02, 2008
  • 1 more comment
  • Andy Bathgate
    Andy Bathgate Nov 03, 2008
    ASUS Board will support 4 pata drives but just to confuse you, when using win 2000/xp you have to set ONBOARD IDE OPERATE MODE In the system Bios to enhanced mode and ENHANCED MODE SUPPORT ON set to SATA try setting these in the bios and let me know it this works
  • Andy Bathgate
    Parallel ATA and Serial ATA device configurations
    Following are the Parallel ATA and Serial ATA device configurations supported by Intel ICH5R specifications.
    Native operating systems (OS) are Windows 2000/XP. ICH5R supports a maximum of six (6) devices using these OS.
    legacy OS are MS-DOS, Windows 98/Me/NT4.0. ICH5R supports a maximum of four (4) devices using these OS.
    Operating System
    Primary
    (2 devices)
    P-ATA Secondary
    (2 devices)
    Port 0
    (1 device)
    S-ATA Port 1
    (1 device)
    - Windows 2000/XP
    V
    2 Windows 98/Me/NT4.0
    Configuration A
    Configuration B Configuration C
    ■/ ■S
    Supported Disabled
    Required IDE Configuration settings in BIOS
    Refer to the following table for the appropriate BIOS settings of the above P-ATA and S-ATA device configurations. See section "4.3.6 IDE configuration" for details on the related BIOS items.
    BIOS item
    Windows 2000/XP
    Windows 98/Me/NT4.0 ABC
    Onboard IDE Operate Mode
    Enhanced Mode
    Compatible Mode
    Compatible Mode
    Compatible Mode
    Enhanced Mode Support On
    S-ATA
    IDE Port Settings
    Primary P-ATA+S-ATA
    Sec. P-ATA+S-ATA
    P-ATA Ports Only
    ASUS P4C800 motherboard user guide
    2-25
    Primary
    (2 devices)
    P-ATA Secondary
    (2 devices)
    Port 0
    (1 device)
    S-ATA Port 1
    (1 device)
    - Windows 2000/XP
    V
    Configuration A ;
    ■/ ■S
    Supported Disabled
    BIOS item
    Windows 2000/XP
    Enhanced Mode
    Compatible Mode
    Compatible Mode
    Compatible Mode
    S-ATA
    IDE Port Settings
    Primary P-ATA+S-ATA
    Sec. P-ATA+S-ATA
    P-ATA Ports Only
    2-25
  • Andy Bathgate
    sorry scan transfer has messed up
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
No manual for conecting mother board
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4sp-mx%20se/e1676a.pdf
CLICK ON THIS LINK AND DOWNLOAD THE USER GUIDE IN PDF FORMAT WHICH U CAN READ ON A ADOBE READER
RAHUL
Feb 22, 2009 | ASUS P4SP-MX Motherboard
My Mb does not give any sign, . What can I do ? Everything is desconnected except power on the Mb and the Mb switch. I switch the machine on and the only thing works is the CPU fan No any beep
Sometimes you have to have the motherboard , power , cpu , memory and 1 drive connected (IE the basic components) to get the system running
Also check the jumper settings where the board connects to the power switch on the case
Jan 22, 2009 | ASUS P4SP-MX Motherboard
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
PATA Harddisk connection
Hi Murtazasoni, if you have the manual for K8V-MX motherboard you shouldn't have any troubles. You can download it from this link, Win XP; http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
The IDE data ribbon only connects to the PATA drive & motherboard in one direction. Please see the top of page 1-22 for instructions. Most data ribbons for IDE drives have three connectors. The connector farthest from the other two connectors (Two connectors very close to each other), is plugged directly to the motherboard as shown & explained on the top of page 1-22.
If you are only connecting 1 PATA drive to the data ribbon, connect it to the last connector on the ribbon, leaving the next connector for another PATA drive.
Setting the jumper on a PATA drive. Every hard disk drive has a large white sticker on it. This sticker includes information about the drive. Things like the model number of the drive. There is also information regarding how the drive is to be set. Example: if the drive is to be the only drive in the system its jumper should be set to (Master drive only). If there is another PATA drive in the system connected to the same ribbon cable than change the jumper on the drive to, (Master with a Slave). The second PATA drive's jumper must be set to, (Slave). Connect the power cable to the PATA drive ['s]. Re-check all connectors (internally) before closing the case. Boot the system & press the Delete key on the keyboard every two seconds until the main bios menu opens. Open your manual to the top of page 2-7. Here you'll learn how to move about while in the bios. At the main menu you should see your PATA drive. Listed to the right of Primary IDE Master you should see the model number of the PATA drive listed. If not than the drive was not connected correctly. Shut down the system. Unplug the power cord from the system, open the case & re-check the data ribbon for correct orientation, solid insertion & solid insertion of power cable to drive. Connect the power cord to the system & boot to the bios again. Once the drive is listed go to the title Boot, section 2.6, page 2-27 & follow the instruction through to page 2-28.
Open your CD-ROM drive & load your windows CD, close the CD drawl.
Save bios changes & exit. The system will auto restart.
The system should start loading windows if you set the boot device correctly as shown in the manual.
If you find this too difficult to follow, suggest you ask a friend with more PC knowledge for assistance.
Mike
Jul 14, 2008 | ASUS K8V-MX Motherboard
Please help
Try pressing F2 / Del key during startup. That should bring the bios setup. Now Restore that defaults & install OS on your HDD. If you are not using Floppy drive, disable the onboard floppy controller from BIOS.
Jun 20, 2008 | ASUS P4SP-MX Motherboard
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
ASUS P4SP-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
