Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Canceling a transmission after I have sent it to the sewing machine
It has happened again. while sending an embroidery pattern to the machine from the computer something didn't go right, tried to resubmit and the machine tells me that I have to cancel the transmission that is in progress. I have tried turning off machine, unplugging macine, undoing the embroidery accessory to the machine, unpluging it from the computer and nothing seems to work. can you help?
  • szasz22 Nov 13, 2008
    I have the same problem and am very frustrated......I can't use my new machine. It seems there is instruction missing on how to delete something that is transmitted to the machine from the computer. The dialog box in which you choose the section to print does not come up either.
    This has to be fixed!!!
    Please help!
  • 3 Answers
Start from the beginning and get the machine ready for embroidery. I found I had not put the feed dogs down when it happened to me
Posted on Nov 09, 2008
My singer furtura ce 200 telling me I have to cancel what has been sent before I can send another design to my embroidery machine....how do I cancel it
The manual should have instructions how to do that:
http://futura-support.com/products/ce-200/manuals
Be sure to check the instructions on your CD. Otherwise, you may want to contact Singer Support.
May 22, 2017 | Sewing Machines
How to transfer embroidery patterns to Brother sewing/embroidery machine
Machine designs first designator is the file name. Your machine shows the file number for the design you want. You do still need to "select" that design number shown to actually begin teh file transfer from a thumb drive or cable direct from your computer if your machine has that feature.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Aug 22, 2014 | Brother SE400 Computerized Embroidery and...
Transition to machine still pending. How do i cancel it
Canceling it takes a few steps, and you may need to do it after each time you do a design. First, close the Futura software on the computer. Then, unplug the USB cord from your machine AND the back of your computer. Also turn off the sewing machine. Do all of this before plugging the USB cord back in. Do that, then turn the sewing machine back on and restart your software. You should be fine.
For whatever reason, your last transmission gets stuck in the "buffer" between the computer and embroidery machine and this will clear it out. It happens to me each time I send a design, and I have to go through this whole song and dance to clear it. Works just fine once I do, though. Good luck!
Apr 01, 2011 | Singer CE-100 Futura Computerized Sewing...
My program tells me to cancel previous transmission. How do I do this, since I don't believe there was a previous transmission?
This happens every time I finish a design. First, close thesoftware on your computer. Next, turn off the embroidery machine. Now unplugthe USB cable from the machine and then from the back of your computer. Nowreverse the progress. This will clear the "buffer" between yourcomputer and the machine. It's a bit of a pain to do each time, but it doeswork.
Nov 30, 2010 | Singer CE-200 Quantum Futura Computerized...
Cancel a pending transmission
Oct 22, 2010 | Singer CE-200 Quantum Futura Computerized...
When I try to send a design to my Quantum Futura CE-200 I get a message that a transmission to machine is still pending, and I must cancel the pending design before I can continue. I have not used the...
Go to futura-support.com Go to FAQ and go to #7. Follow the procedure EXACTLY, save one thing that is not on there. BEFORE you do anything, make double-sure your machine is set for embroidery (E) and not sewing (S). Even if you follow the procedure exactly, if your machine is on 'S' and not 'E', you will continue to get the 'transmission' message.
May 23, 2010 | Singer CE-200 Quantum Futura Computerized...
My 270D machine keeps stopping and resetting in the middle of a pattern. I have to turn the machine off and go to the correct screen to start again. I take it forward to where it stopped and within second,...
Sounds like it thinks it doesn't have room to finish the rest of the design - my Janome does that sometimes too. Can you rehoop it? or maybe a faulty pattern.
Feb 09, 2010 | Brother SE-270D Computerized Sewing...
By switching sewing machine off.
But if you are talking about message "A transmission to machine is still pending..." you need to update your software.
Aug 20, 2008 | Singer CE-200 Quantum Futura Computerized...
Programing
program-controlled sewing or embroidery machine comprising a stitch-forming device (2), an integrated microcomputer (4), at least one memory (16, 17) and at least one data interface (5), as well as a keyboard (12) and a display (11) for entering and monitoring or checking values for program control. To retrieve sewing or embroidery pattern data from a remote computer (mailbox) in a simple manner, the data interface (5) of the sewing or embroidery machine (1) is able to be connected directly to the mailbox (10) of a central computer (9) via a data transmission connection (7) via a corresponding modem (6), and the structural units which are necessary for communication with the mailbox (10), such as display (11), keyboard (12) and memory (16, 17) are disposed in the sewing or embroidery machine (1) itself, with the functional processes necessary for communication with the mailbox (10) being able to be controlled and monitored by the microcomputer (4) necessary for controlling the program of the sewing or embroidery machine. The invention further relates to a method of operating program-controlled sewing or embroidery machines.
Mar 17, 2008 | Elna Quilter's Dream 6003Q
Cancelling a transmission
You must remember your machine acts like a printer. It will only accept another pattern once the current one is finished. A common fault amongst many users are that they send another pattern while the machine is busy with the current pattern. The correct procedure would be to cancel the current pattern, before sending another one.
You do this by clicking on "exit". Another window will open and ask you if you want to terminate the current transmision to the machine.
If you send one pattern over the current one, your machine is capable of queing and the only wat to resove the issue is by switching the machine off and leaving it off for 60 seconds and resend your nwe pattern
Hope this help you
Dec 10, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
93 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
